| | | Forums66 Topics128,094 Posts1,056,157 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#85138 05/07/2002 4:01 AM | Joined: Sep 2001 Posts: 85 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2001 Posts: 85 | Hi all, I am in the process of doing a lot of work to the cab of my 59 1/2 ton. The wipers have never worked very well, but here in the Desert, it doesnt matter that much. Anyway, I took the motor out to clean and lube it, install new arm bushings etc.
Questions: Did GM offer a single speed wiper motor (electric) in 59? My switch has continuity to ground in one position only, and there only seems to be 2 positions for the switch instead of the 3 I would expect with a 2 speed wiper. The switch looks factory, the wiring plug fits ok and so on. This makes me think it is the original switch.
Next: Am I correct in assuming the switch is the ground for the wiper motor? I only get a complete circuit when I test from the power wire to the switch body. Any insight appreciated | | |
#85139 05/08/2002 4:04 AM | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | Can't say for sure on '59, but I had a bottom of line '64 GMC that only had a single speed wiper motor.  | | |
