| | | Forums66 Topics128,043 Posts1,055,605 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2011 Posts: 835 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 835 | I usually buy the filters for my '53 powerglide engine by the case, so it has been a while since I purchased a filter. I am getting down to the end of my supply, so I thought I would check into availability. The last filters I bought were NAPA 1100. I was at NAPA and asked to see one of these filters. The diameter of the old filter was 4.5 inches. The new filter is 4 inches. The included gasket was the correct size. Checked at Carquest. Same thing. I think both filters are made by WIC.
The smaller filter would fit fine, but I think the older filter would have more filter medium in it.
Curious to know if there is a better choice of filter available rather than the WIC/NAPA/Carquest?
Kurt | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Some of those bypass filters are Fram & some are AC. They used to take different cartriges. Now they have consolidated them into one part #. I dont know if any of the other brands have separate #s for those. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | A Fram C4P is 4.5 diameter ...pic... ...pic... The wix 51006 they just sold me to replace it is only 4 inch diameter . I'm going to try to find a Fram They claim it crosses. | | | | | Joined: Aug 2011 Posts: 835 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 835 | Let me know if you find the Fram. Thanks,
Kurt | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | I could not find the fram C4P locally. I ordered 3 from rockauto.com. | | | | | Joined: Aug 2011 Posts: 835 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 835 | Thanks for the tip. Ordered 4 myself. Seemed to be just a few cents difference in shipping 4 as shipping 1. Cheaper than Much the WIC filter from NAPA or CarQuest.
Kurt | | | | | Joined: Aug 2011 Posts: 835 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 835 | Got the Fram filters from RockAuto today. Right size, right price. came with two gaskets, same outside diameter, but one wider than the other.
Kurt | | | | | Joined: Dec 2003 Posts: 1,144 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,144 | Do you remember the part number of the smaller filter. just tried a wix 51006. the supplied gaskets were to large the filter was about 1" too long for the canister. The filter I took out measured 3.75" diameter and was 4" tall. the engine was in a 54 4100. | | | | | Joined: Aug 2011 Posts: 835 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 835 | Sounds like you have an even smaller filter than the WIX 51006, NAPA 1100 or Fram C4p. What is the number/brand on the filter you took out? Might try to cross that.
Kurt | | | | | Joined: Dec 2003 Posts: 1,144 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,144 | So far I haven't found a number either stamped or printed on filter, I tried the 51006 again and just succeeded in getting it stuck and ruined it getting it back out. Maybe in the light of day after it drains overnight I will find a number. both of the gaskets supplied with the 51006 are too large for the top of canister. Every site I've been to recomends the 51006, it's eqivelant or something larger. | | | | | Joined: Aug 2011 Posts: 835 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 835 | maby you have a non-standard filter from a different vehicle?
Kurt | | | | | Joined: Dec 2003 Posts: 1,144 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,144 | The local jobber came up with AC Filter P 203. The filter appears to fit, the gaskets did not. So tommorrow I'll see about gasket material. I measured the remote filter on the 38 it is larger than on the 54 motor.No telling what the remote filter set up was actually designed for. what paint still attached is orange both canister and top.
