3 members (Gdads51, Bill Hanlon, TexasJim50), 329 guests, and 6 robots.
Topics128,162
Posts1,057,068
Members48,463
does the front fender support braces bolt to the radiator support frame and to the fender, the reason I ask is the braces look like they take a carrage bolt, if you have any pictures that would be great, Thanks
I don't know about a 42 but my 37 took a carrage bolt, 2 per side. Yes, it does go through the rad. support brace. I had to snake them through the radiator frame with mig welding wire.Just wrap it around the bolt after feeding it through the fender side. Then gently pull it back to fit it into the square bolt hole. It takes a little practice but can be done. After you get the first one through place a nut on it to hold it in place. I used SS carrage bolts from Home Depot. Can't give you a pix as it is in place.
Al
Like your '37, APV! Good job!
1940 Chevy 1/2 ton pickup "KC"
A day without sunshine is like, well, ..... dark!
I found out that they do go the way I tought and they just never change the design from the older trucks were they used carrage bolt to bolt to the radiator support
My '41's go all the way through the radiator frame/support and they are a carrage bolt. However the heads are larger in diameter and flatter than standard carrage bolts
1941 Chevy Master 3/4-Ton
More images in the Bolt Bucket
Born to fish, the truck is only a hobby.
