| | | Forums66 Topics128,160 Posts1,057,054 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2011 Posts: 20 New Guy | | New Guy Joined: Oct 2011 Posts: 20 | does the front fender support braces bolt to the radiator support frame and to the fender, the reason I ask is the braces look like they take a carrage bolt, if you have any pictures that would be great, Thanks | | | | | Joined: Dec 2009 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2009 Posts: 66 | I don't know about a 42 but my 37 took a carrage bolt, 2 per side. Yes, it does go through the rad. support brace. I had to snake them through the radiator frame with mig welding wire.Just wrap it around the bolt after feeding it through the fender side. Then gently pull it back to fit it into the square bolt hole. It takes a little practice but can be done. After you get the first one through place a nut on it to hold it in place. I used SS carrage bolts from Home Depot. Can't give you a pix as it is in place.
Al | | | | | Joined: Mar 2011 Posts: 457 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 457 | Like your '37, APV! Good job!
1940 Chevy 1/2 ton pickup "KC" A day without sunshine is like, well, ..... dark! | | | | | Joined: Oct 2011 Posts: 20 New Guy | | New Guy Joined: Oct 2011 Posts: 20 | I found out that they do go the way I tought and they just never change the design from the older trucks were they used carrage bolt to bolt to the radiator support | | | | | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | My '41's go all the way through the radiator frame/support and they are a carrage bolt. However the heads are larger in diameter and flatter than standard carrage bolts | | |
