6 members (Wally / Montana, WICruiser, GMCJammer51, Ole49GMC, 2 invisible), 103 guests, and 1 robot.
Topics128,196
Posts1,057,385
Members48,469
#849308 05/07/2012 12:57 AM
We're trying to figure out where we can get this line, or at least the end fixtures. Or a way to replace it and fit the rubber hose to the metal lines.
here's a picture:
http://s271.photobucket.com/albums/jj155/turpentyne/
Year and make?
Here is a replacement kit. It is for 37-54 Chevrolet trucks.
Maybe someone will post a link to a recent thread that discussed where to by parts piece-by-piece?
Crusing in the Passing Lane
If you use the suggested Cu line, make sure to put some loops in it to absorb the engine vibration.
EdPruss #851181 05/13/2012 8:14 AM
Most older parts stores sell the copper line by the foot,and the fittings and ferrules to go with the line,also the plastic line kits are available from anywhere that sells gauges. They usually use the same fittings as the copper lines.
Speed
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'66 Pontiac Catalina
'76 Chevy 1 ton Duallie
'84 Bronco II
'78 Dodge W-200
'81 Toyota 4X4 truck
I'll just add that any good plumbing supply outlet will carry the copper tubing, nuts and ferrels as well
1945 Chevrolet G 506 1.5 Ton Military 4X4
1967 Jeep Cj5 with 283 SBC
