| | | Forums66 Topics128,101 Posts1,056,182 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 173 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 173 | I'm trying to chase down a problem with my '46 235. the engine lugs on acceleration. I've put in points-condinser, wires, plugs, set timing, and cleaned carb. I replaced the plugs and that was the only step that didn't lead to any improvement. In fact the new plugs probably made the truck run worse. There were Autolite 4194's gapped to 0.020 in the truck so that's what I replaced them with. I gapped them to 0.040, per the manual. The truck has a pronounce backfire now, that is worse than before. I may go back and cut the gap down some and see if that helps. Is there another plug, or a different gap that y'all recommend? I've seen an Auotlite 3136 mentioned upon searching the forums. In running these in a '46 two ton, but probably will never really load the old girl that much. Thanks, Scott
Forgot to mention these are the small 10mm size plugs.
1947, 1950, & 1952 Chevrolet 1/2 ton 1952 GMC 450 series Cab Over Engine 1946 Chevrolet 2 Ton
| | | | | Joined: Apr 2005 Posts: 396 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 396 | Why the .040 gap on new plugs when replacing older ones with .020? Jerry
| | | | | Joined: Nov 2006 Posts: 173 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 173 | The service manual lists the gap as .040". That's where I got that number from.
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Sounds like you have weak spark If it runs better with the smaller gap. Thats probably why someone set the gap so close on the old plugs. You may have a bad coil or the wrong coil. Is it still running 6 volts? They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Nov 2006 Posts: 173 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 173 | Yes, I'm still running 6v. I didn't replace the coil, as it is the original style where the wire for the distributor comes out the bottom. I may have to end up getting one of those, I don't suspect that is a FLAPS item. I also ordered some Autolite 3136 as NAPA shows those as correct for the application. We shall see what difference that makes.
