3 members (Joe H, Gdads51, UtahYork), 99 guests, and 2 robots.
Topics128,264
Posts1,058,355
Members48,485
#85095 03/31/2005 2:17 AM
We're putting a 56 cab on an 89 4x4 full size chassis, using the original 56 gauges and the tank and sender from the 89...or at least I hope so. What kind of problems will we run into? Can these be made to work? Any thoughts/suggestions appreciated before the smoke starts rolling. Thanks, Steve
#85096 04/02/2005 5:53 AM
what engine? gas gauge won't work, or at least won't read right - other gauges should - let us all know how you deal w/ mounting the cab and front sheet metal! grin
#85097 04/02/2005 12:35 PM
Cab is a 4400 series and already mounted on the 89 chassis w a 350/5spd. Moved the firewall back a bit for the the HEI. Cab sits well on the frame, 33's fill the wheel openings. Bummer about the gas gauge though because the original cluster is in great shape. Guess I'll have to keep track of miles.
#85098 04/04/2005 5:38 PM
I got a feeling that somebody with a box of resistors couls make your gas guage work. It's an electrical circuit and can be manipulated, all it is (I think) is a ammeter with an F at one end and an E at the other. Don't give up, find an engineer.
"Happiness equals reality minus expectations" - Tom Magliozzi
#85099 04/05/2005 4:10 AM
Jim Bow, thanks, yeah I thought so too but I'm not sure what the resistance is on either the old gauges or the new sender. Guess I could get the 89's stats at a Chevy dealer...the 56 is a little long in the tooth for finding that stuff. O well, guess work and smoke...hope it ain't smoking in the gas tank though that could get ugly.
#85100 04/05/2005 4:21 AM
The 89 runs from 0-90 ohms. Dunno about the 56...
Hold the sender in your hand, wired and grounded to the truck , and move arm up and down slowly, see how guage follows. Safe easy test.
John Kennedy
1950 Suburban street rod
Pics in the Gallery.......
new site up!
http://home.joimail.com/~kennedyjp/
