| | | Forums66 Topics128,264 Posts1,058,352 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#85095 03/31/2005 2:17 AM | Joined: Mar 2005 Posts: 25 Member | | Member Joined: Mar 2005 Posts: 25 | We're putting a 56 cab on an 89 4x4 full size chassis, using the original 56 gauges and the tank and sender from the 89...or at least I hope so. What kind of problems will we run into? Can these be made to work? Any thoughts/suggestions appreciated before the smoke starts rolling. Thanks, Steve | | |
#85096 04/02/2005 5:53 AM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | what engine? gas gauge won't work, or at least won't read right - other gauges should - let us all know how you deal w/ mounting the cab and front sheet metal! Bill | | |
#85097 04/02/2005 12:35 PM | Joined: Mar 2005 Posts: 25 Member | | Member Joined: Mar 2005 Posts: 25 | Cab is a 4400 series and already mounted on the 89 chassis w a 350/5spd. Moved the firewall back a bit for the the HEI. Cab sits well on the frame, 33's fill the wheel openings. Bummer about the gas gauge though because the original cluster is in great shape. Guess I'll have to keep track of miles. | | |
#85098 04/04/2005 5:38 PM | Joined: Oct 2001 Posts: 578 'Bolter | | 'Bolter Joined: Oct 2001 Posts: 578 | I got a feeling that somebody with a box of resistors couls make your gas guage work. It's an electrical circuit and can be manipulated, all it is (I think) is a ammeter with an F at one end and an E at the other. Don't give up, find an engineer.
"Happiness equals reality minus expectations" - Tom Magliozzi
#85099 04/05/2005 4:10 AM | Joined: Mar 2005 Posts: 25 Member | | Member Joined: Mar 2005 Posts: 25 | Jim Bow, thanks, yeah I thought so too but I'm not sure what the resistance is on either the old gauges or the new sender. Guess I could get the 89's stats at a Chevy dealer...the 56 is a little long in the tooth for finding that stuff. O well, guess work and smoke...hope it ain't smoking in the gas tank though that could get ugly. | | |
#85100 04/05/2005 4:21 AM | Joined: Sep 2001 Posts: 109 Member | | Member Joined: Sep 2001 Posts: 109 | The 89 runs from 0-90 ohms. Dunno about the 56... Hold the sender in your hand, wired and grounded to the truck , and move arm up and down slowly, see how guage follows. Safe easy test.
John Kennedy 1950 Suburban street rod Pics in the Gallery....... new site up! http://home.joimail.com/~kennedyjp/
