1 members (Hotrod Lincoln),
57
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,094 Posts1,056,066 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 207 Shop Shark | | Shop Shark Joined: Mar 2010 Posts: 207 | Couple of questions:
1. Did any of the 1965 trucks with the 230 have a tachometer? 2. Does anyone make a tach that will work with the inline but still look like the stock V8 tachs?
I can find the V8 tachs in all of the typical magazines but I never see one for the inline 6.
Tom 1965 Chevy C10, 230 straight six, 2WD, 4-speed manual
| | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | I don't know about an original stock tach, but you can purchase tachs that can be set for 4,6,8 cylinder readout. The usually have a small switch on the back to select the number of cylinders. I have one.
Drew
| | | | | Joined: Jun 2010 Posts: 4 New Guy | | New Guy Joined: Jun 2010 Posts: 4 | Sun Tach FZ88R is an 8,ooo RPM 90 degree sweep tack that will work with some modifications for mounting in the dash. | | | | | Joined: Jan 2010 Posts: 45 'Bolter | | 'Bolter Joined: Jan 2010 Posts: 45 | I got an tach from an old boat with a Mercruiser io. Came with a six cylinder. Looks a lot like a stock tach to me. | | | | | Joined: Aug 2007 Posts: 462 'Bolter | | 'Bolter Joined: Aug 2007 Posts: 462 | You need the tach and transmitter from a 60-63 | | | | | Joined: Mar 2010 Posts: 207 Shop Shark | | Shop Shark Joined: Mar 2010 Posts: 207 | Thanks guys,
I'll see what I can find in the 60-63 variety.
