3 members (Gdads51, JoergK., 1 invisible), 91 guests, and 3 robots.
Topics128,181
Posts1,057,150
Members48,464
Big Bolt Forum Co-moderator
I wasn't going to buy one, but I noticed the dings on the back of the cab on my 48 two ton are right where it is boxed in by the interior supports. I can't get a dinging hammer to it. So I am going to open up for the HF stud gun. It is on for $99 and I have a coupon for 25% off. For $75 and probably limited use, I'll go for it. I don't know how to get the dings out any other way. Don't want to drill holes.
1948 Chevy 2-Ton
Super55,
You won't regret it. I tried mine on those cab dings last week with a lot of success. I'm trying to use as little bondo as possible. I was able to pull small dents so that only high build primer will be necessary. I borrowed some techniques from the paintless dent removal guys. Here's what I found that works:
I polished the area so that I could watch the reflection while I pulled the dent. A fluorescent light works great for the reflection.
I only used a short pulse to weld the studs. The studs can be twisted off and reused a couple times.
Instead of using the slide hammer, I made a "bridge" tool. It's a steel bar with a small hole that is supported at each end about 3/4" away from the surface. The welded stud pokes through it and I pull it slowly with a pop rivet gun. Very controllable.
A dent the size of a quarter may require 8 pulls or more to progressively bring the surface up where it should be.
Use a sanding block to scuff it lightly to see if you have any high spots. Tap them down a little if necessary.
When you're satisfied, lightly draw file over the area.
Dave Evans
52_3100
Hey thanks for the tips. I picked up the stud gun. I'll try your pop rivet tool idea. Sounds like a very good idea.
1948 Chevy 2-Ton
Super, did they let you combine the 25% off coupon with the sale price?
Ed Miller
'58 Apache short Fleetside half ton Napco
Falls City, OR
Oh no, if you read the fine print on those coupons they can not be used on welders, tool boxes... etc. All the big ticket stuff.
I did read it before I went to the cashier, but she also brought that to my attention.
1948 Chevy 2-Ton
So, are you going to come over and pull the dents in my fenders to practice Paul?
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1949 GMC Panel Truck
1926 Model TT Truck
You should have just left it with me!
1948 Chevy 2-Ton
Hahaha! The old bus has had another 900 miles or so on it now. That's allot of walking!
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1926 Model TT Truck
I've got a HF stud gun and it works great.
Moderated by  MNSmith
