Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
4 members (baldeagle, 66flea, GMCJammer51, ndkid275), 39 guests, and 3 robots.
Topics128,004
Posts1,055,246
Members48,418
#850309 05/10/2012 4:19 AM
Hope this isn’t too much of a basic question but when I bought my truck a previous owner put a fuel filter on it between the tank and the fuel pump. I also have one between the pump and carburetor. I need to change the filter that is between the tank and the pump.
Do I need to disconnect the line at the sending unit? Or can I equalize the pressure by just taking off the gas cap so the gas isn't sucked down into the line? Not sure how to proceed. Best case scenario I would only want to drain the gas that is already in the line. I have this fear of having jugs of gas all over the garage.
Thanks for your help.
Mark
1956 Chevy 3200, 1/2 Ton, 235 CI
https://photos.app.goo.gl/TQQo1YnFjs3U7xB57
MarkT #850320 05/10/2012 6:27 AM
the gas cap is vented, there is no "pressure" involved, the gas could siphon regardless .... you could open the line at the sender, or you could have everything ready, including a pan to catch the gas, remove and replace the filter as quick as you can, not likely to get more than a cup or so out if you're not too fumble fingered wink if there's a long enough rubber line before the filter you could also clamp it there while you work
Flxible #850325 05/10/2012 7:00 AM
Also, if you got a rubber line, you can shove a pencil in the end to stem the flow.
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1949 GMC Panel Truck
1926 Model TT Truck
Mr. Lang #850358 05/10/2012 1:23 PM
Riding in the Passing Lane
I take the line loose going into the filter & blow some air in it to break the siphon efect. I take or loosen the gas cap first.
Your PO had it right.
1972 Chevy c10 Cheyenne Super
Thanks guys. I appreciate it. I've got a bucket ready for spillage if needed.
MarkT #850594 05/11/2012 3:32 AM
you could just drive it till you "run out of gas" change the filter, call the wife and have her bring you a couple of gallons nono ,but not on Mother's Day though.
....David
54barnfind #850621 05/11/2012 5:06 AM
HaHa.... good one. The weekend after Mother's Day.
