8 members (Otto Skorzeny, Steelonsteel, Gdads51, J Lucas, Peggy M, dt235sd, walter74, klhansen), 127 guests, and 3 robots.
Topics128,036
Posts1,055,454
Members48,422
#85014 01/22/2004 6:10 AM
What's the best place to "hide" a couple of modern speakers to go with a custom autosound stereo in my '65? The gas tank is still behind the seat...
I heard one time that you can put TWO 4" speakers in the same hole that the stock 6x9 occupied. Has anyone done anything neat? Just wondering.... :confused:
The shortest distance between two points is probably under construction
#85015 01/22/2004 12:14 PM
There are several places you can put 2 speakers to get nice sound.
1. They make kick panel speakers to go where the floor vents are.
2. They make a daul speaker to mount where your single speaker went under the dash.
3. You can hide two low profile speakers under the seat.
1960 GMC 305A V-6 Gallery Page
Remember, the government cannot give --anything to anyone --that they have not first taken away from someone else.
BUY AMERICAN http://www.stillmadeinusa.com/index.html
#85016 01/26/2004 4:31 AM
In this thread I described a 5-speaker stereo system I hid in a '57 p/u. This is overkill... he was extremely concerned about stereo separation and leaving almost no clues for potential theives.
I still don't like kickpanel speakers, they always sound muddy to me. Get the source close to ear level if you want any fidelity. Dual mids in the dash will give clarity, but not stereo separation. Adding tweeters in the corners of the roof will compensate for this. A sub can be mounted anywhere, since the lower the frequency range the harder it is to determine the source.
1955 First Series GMC 250 1-Ton Panel
Mr. Hedgehog - Follow the build
If you can't laugh at yourself, I'll laugh at you.
#85017 01/26/2004 6:14 AM
There isn't a lot of space in an old pickup cab for a sub if the gas tank is still behind the seat.
1954 GMC De Luxe COE
#85018 01/27/2004 9:39 PM
Mounted my fully enclosed truck speakers using an angle bracket and stovebolts through holes we drilled in the top welded flange of the gas tank behind the seat. Worked well for our application but sound somewhat muffled.
1956 Chevy 3100
261/700r4 (formerly 3 speed OD)
More pix on Photobucket
#85019 01/28/2004 12:31 AM
I experimented with speakers in my truck before I did the final install, and got great results!
First -- 4 speakers were just too many ... sound bounced all over the cab. Two speakers were best, and the best spot, for me, was in the kick panels ... but I angled each one so that the driver side speaker pointed up towards the passenger's head and vice versa.
Then I bought Sony Xplod speakers. The real trick in getting good sound is to match the wattage of the speakers correctly to your unit. The details are at my site:
Designing and Building Speaker Cabinets[/b]
[b]My Radio Install
~~ Alan Horvath
1954 Chevy Pickup
Singing his praises in the
Passing Lane
