0 members (),
40
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 55 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 55 | My 46 is very hard to start when warm. I have a spacer between the carb and manifold. Any other fixes? b51r
b51r
| | | | | Joined: Jun 2010 Posts: 301 'Bolter | | 'Bolter Joined: Jun 2010 Posts: 301 | What's your compression read cold and when hot? Does choking it help start when hot?
1949 Chevy 3600 1975 W-25 Hurst Olds 1970 GMC 1/2 ton Fleetside 2010 Chevy Silverado
| | | | | Joined: Oct 2006 Posts: 55 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 55 | I don't like to choke it then it floods.
i pump it a couple of times and then hold about 1/2 down, this sometimes works after a lot of cranking.
b51r
b51r
| | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | I had a truck like that, I found that cranking the engine a few revolutions before giving it any throttle would make it start easier when hot. Sometimes when hot, the gas will percolate into the manifold, and the mixture will be too rich when you hit the starter, so by cranking with no throttle, it pushes this out into the tailpipe. | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Have you checked the condition and operation of your heat riser valve and counter weight | | |
