4 members (jmoore, TUTS 59, 68ironhead, 3B), 105 guests, and 4 robots.
Topics128,026
Posts1,055,404
Members48,422
#850109 05/09/2012 4:13 PM
My 46 is very hard to start when warm. I have a spacer between the carb and manifold. Any other fixes?
b51r
b51r
b51r #850124 05/09/2012 5:48 PM
What's your compression read cold and when hot? Does choking it help start when hot?
1949 Chevy 3600
1975 W-25 Hurst Olds
1970 GMC 1/2 ton Fleetside
2010 Chevy Silverado
bztguy #850397 05/10/2012 3:18 PM
I don't like to choke it then it floods.
i pump it a couple of times and then hold about 1/2 down, this sometimes works after a lot of cranking.
b51r
b51r
b51r #850400 05/10/2012 3:21 PM
I had a truck like that, I found that cranking the engine a few revolutions before giving it any throttle would make it start easier when hot. Sometimes when hot, the gas will percolate into the manifold, and the mixture will be too rich when you hit the starter, so by cranking with no throttle, it pushes this out into the tailpipe.
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1949 GMC Panel Truck
1926 Model TT Truck
b51r #850426 05/10/2012 5:12 PM
Have you checked the condition and operation of your heat riser valve and counter weight
