:)howziit OldArmy!
i've had some background in army aviation electronics, and my Verizon career, so i always treasure my trusty volt-ohm meter(VOM), as a must-have tool.
it has also served me well, in trouble-shooting auto electrical problems, and can be purchased very cheaply.
be very sure that the battery is disconnected!
NOW...using this simple tool handy, turn the ignition switch to the "7 o'clock position". using the two meter's leads, touch any two screw terminals, until you get a reading of ZERO on the meter.
make a note of which terminals; these are your IGNITION ON positions.
NOW...turn the switch to the "4 o'clock position". touch any two screw terminals,so you get the ZERO reading.
note these terminals; these are your ACCESSORIES position.
if you have a fourth spring-loaded "9 o'clock position", touch any two terminals, for a ZERO reading.
note these terminals; these are your STARTER ON position.
looking at your notes, you will find ONE terminal that is common to all the tests.
THIS IS YOUR BATT+(hot lead); all the other leads are where you hook up ignition,accessory, and starter.
JMO, buy an ohm-meter, and practice with it. it will save you lots of unnecessarily-cut wiring, major headaches, untimely stalls, and $$$$ given to the repair shops.
makes you feel good to know which goes where,and why... even if all the wires were same color.
hope this helps.
