7 members (klhansen, Peggy M, Cletus1950, TUTS 59, papas52, Bill Hanlon, 1 invisible), 89 guests, and 3 robots.
Topics128,172
Posts1,057,038
Members48,458
Junior Member
Junior Member
I took her out of the driveway for the first time the afternoon!! Problem: she runs perfect in the driveway (idles/revs good) and went around the block with good power a few times until she quit. pulled over to the shoulder and waited half minute-fires up and runs for 15-20 seconds then quits (took me 10 mins to get the two blocks home :mad:
I checked the fuel to the carb-good. Thinking it might be electrical. What would make it run good for a short time and then die like I turned off the ignition???
Thanks for the help in advance smile
ND
A bad coil could do that. I had that on an old tractor once. It ran fine when it was cold-but as it warmed up, the coil would start to cut out. Just a thought.
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
Does your carb have an automatic choke? I put the spring in backwards once and mine did the same thing.
Junior Member
Junior Member
Thanks for the replies, I have installed all new ingnition parts including the coil. I have ran the motor in the driveway several times up to operating temps but I'll keep an eye on the coil.
I do have an auto choke however everytime I check it after it dies I look it over good and I didn't notice the choke shut (I have the filter off)
Thanks for the ideas, I'll keep you posted!!
ND
