1 members (Hotrod Lincoln),
60
Mod | | | Forums66 Topics128,009 Posts1,055,293 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2011 Posts: 112 Shop Shark | | Shop Shark Joined: Nov 2011 Posts: 112 | Does anyone know what a Harrison heater with the identification H-2-47 mean? What year it fits and is it a truck or car heater? | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | That model Harrison is in my 50 ...pic... It draws fresh air from the louvers on the passenger side If the motor is original it's 6v | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | oldburbs,
Do you want to know what H-2-47 means, and/or do you want to know what kind of heater you have?
If the latter, can you post a photo of the front of the heater?
Harrison made a variety of styles of heaters for GMC and Chevrolet trucks between 47-55.
| | | | | Joined: Nov 2011 Posts: 112 Shop Shark | | Shop Shark Joined: Nov 2011 Posts: 112 | What the h-2-47 means? Thanks Tim. Dave
| | | | | Joined: Mar 2004 Posts: 6,212 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,212 | I believe that's a date code...August 2, 1947 Mike B  | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | What the h-2-47 means? Thanks Tim. Dave Good Question I always thought it was a Model # Harrison gave that heater. ...mine is H-02-47... . | | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | I don't know, but I kinda believe that the number is a model number, too. The number on my '54 Fresh Airflow heater is stamped into the case. < HD 04 54 >< HEATER >
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I also do not know; however, I think that the codes on Harrison radiators and heaters were not the date they were installed or manufactured.
It might have been the date of the first year of that style heater/radiator?
However, Lonnie's 1954 heater would have been a style also used in 1953 (maybe the color was different in 1953)?
I'll check some of the 53-55 fresh-air/air-flow heaters that I have. Lonnie, where on the heater-case did you find that first code?
| | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | Tim - The number is on the outside of the rear case that houses the finned water element, and it faces the firewall. (obviously, I don't know the correct name of the "finned water element." I shot these pics before I rehabbed my heater: > Wider view of number in my previous post. The front cover of the heater is still attached in this photo. Visable thought the round opening. > Full view of the case with number. Only the "54" shows in the photo, a couple of inches right of the red arrow. The front cover was removed in this photo. This photo is higher resolution so that you can move it around and see the details. Hold "Cntl" and tap "+" to enlarge. > Heater partially disassembled.Let me know if you need more pics to determine the location of the number.
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Thanks, Lonnie.
I'll be able to find codes on three of the heaters that I have: two 54/55 GMC heaters and one Chevrolet heater. I'll not be able to heck theone on the Suburban.
| | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | My heater says H-2-46. As far as I know, my heater came out of a late 40s Chev car. | | |
