| | | Forums66 Topics128,023 Posts1,055,371 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2012 Posts: 75 Shop Shark | | Shop Shark Joined: Mar 2012 Posts: 75 | I've aquired several 6 volt sealed beam headlight bulbs from my dad and i was wondering if someone knows if there was a certain brand that chevy used in the factory? also wondering what the# 2 at top of light is? I have tung sol, westinghouse,GE, autolight,guide with a T3in diamond in center of bulb, I once heard that early bulbs did not have nipples any help is appreciated
David 1941 chev 1/2 ton PU 1945 willys MB | | | | | Joined: Mar 2011 Posts: 457 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 457 | I remember reading about when the alignment bumps came out, but don't remember the year. Probably late 40s, early 50s. Google it. I do remember T3 headlights as factory in the early 60s.
1940 Chevy 1/2 ton pickup "KC" A day without sunshine is like, well, ..... dark! | | | | | Joined: Mar 2012 Posts: 75 Shop Shark | | Shop Shark Joined: Mar 2012 Posts: 75 | Ok some other forums said 70's 80's for sure had alignment(aiming)bumps but could'nt find exact year, so I'm thinking my 41 should'nt does anyone know if Guide was correct for sure??
Thanks | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I remember when the alignment bumps came out. It was in the mid 50,s. I still have a Hoppy alignment kit. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | "Guide" is the correct OEM. | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | I know that my passenger side headlight stopped working
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | Joined: Mar 2012 Posts: 75 Shop Shark | | Shop Shark Joined: Mar 2012 Posts: 75 | Ok so I thought I had a set of guide bulbs but I dont does anyone have a extra set of 6volt they want to sell? | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | I have a few 6V bulbs in a box, I'll take a look and see what I got. Posting here so you can PM me later if I forget.
| | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | I have one GUIDE light. This is a used bulb and has no alignment nubs, the back is black and it has a rubber around the rim. All the bulbs I saved were tested three years ago.
I also have a pair of matching GE 5040s bulbs, with the alignment nubs.
Sent you a PM with links to pics. | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | Can somebody verify if this is the right plug for Davids 41? Back side of Guide headlight. | | | | | Joined: Apr 2012 Posts: 44 'Bolter | | 'Bolter Joined: Apr 2012 Posts: 44 | I remember reading a good article about the T3 6 volt headlights. Came across quite a few listings for NOS AC, Guide and a few more. Just remember that some of these lights might be still boxed but might be over 60 years old, if I remember correctly the electrical prongs were sealed in with shellac and the first time you power them up..Pooof..Might be good for show display but I would change them out for daily driving.
There is not a tool made that if you don't try hard enough you can't break! 1952 3100 261 T5 3.08 Gov Locker
