2 members (IHPWR, Otto Skorzeny), 147 guests, and 1 robot.
Topics128,157
Posts1,056,878
Members48,458
Hopefully this doesn't come across too ignorant, but I didn't get any instructions with my manifold, and I can't seem to find an answer on line so I'm going to ask it here. What are the two threaded holes for on the face of the manifold toward the back behind the carb?
I am bound and determined to make this thing work in my 41 GMC with 700R4 AOD. I could have just put in a SBC crate engine an would be driving it by now for less money, but I had to be different, and now I have to turn to you folks for help.
Thanks in advance for your help.
3B Offline
Hy Tim S, I can't be sure without seeing a picture, but is probably a place to bolt a throttle linkage pivot to, hope that helps.
Is this a single or dual carb manifold?
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
It's a single four bbl. I'm talking about the two larger tapped holes side by side toward the back. They are not the same size. I have figured out that at least one is for vacuum, but are they both? Which one for which? If I don't use both of them, should I just plug one?
Thanks for your help.
Tim S.
