6 members (FishinToms53, Southerntruck, Opelika Tom, Hotrod Lincoln, frogfarmer, 3B), 177 guests, and 3 robots.
Topics128,089
Posts1,056,433
Members48,443
Does anyone know if the trim for a 1 1/2 ton will fit 1/2 ton? I found a truck with all the pieces I need but don't know if they swap out. I know the seat did not fit just right. Seemed the cab was shorter. Thanks
It should all work ok.
Your best bet is to measure the cab. I know the fenders were different, but not sure if the cab dimensions were the same.
My 46 GMC on Photobucket
Moderated by  ndkid275, Phak1
