7 members (32Fordpuchoptop, Nhluvstruck, 1955 1 Series, Steve 210, DHedrick, Bill Hanlon, 1 invisible),
153
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,114 Posts1,056,283 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2011 Posts: 139 Shop Shark | | Shop Shark Joined: Nov 2011 Posts: 139 | Getting ready to sandblast frame. Structurally it's all good but there are a couple areas with some extensive pitting and another few areas where the edge is thinned out. Wondering if I should try to build up then grind down the pitts/thin spots or use some sort of filler? Any suggestions would be welcome. Thanks. I plan on using POR15 for the finish. | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | AFAIK POR-15 will NOT adhere correctly to plastic filler/bondo.
If the areas aren't structural you might be able to lead solder them although i'm not sure if the POR will stick to that either.....
You could try a practice run on an old piece of scrap metal first. 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Jun 2001 Posts: 793 Bondo Artiste | | Bondo Artiste Joined: Jun 2001 Posts: 793 | After repairs and filler application after they are primed por 15 should adhere just fine. Call the Por 15 service line and ask them about primers that work well with Por 15.
~ Phillip 1949 GMC Suburban - 10 year project 1952 Pontiac Chieftain Convertible straight 8 hydramatic 1945 GMC half ton truck - Driver- Sold 9-15-25 1946 Chevy COE - SOLD 1-5-26 BUH BYE CHEVY! 1959 GMC Half ton long bed NAPCO | | | | | Joined: Nov 2011 Posts: 139 Shop Shark | | Shop Shark Joined: Nov 2011 Posts: 139 | Thanks for the input. I looked at the POR15 site and they have a thickened POR15 in tubes that works as a filler. Figure I'll use that for the smaller pits. Guess I'll see what's left after sandblasting and decide how to proceed with deeper pits and thin areas. | | |
