0 members (), 155 guests, and 4 robots.
Topics128,110
Posts1,056,241
Members48,437
#848808 05/04/2012 1:08 PM
Getting ready to sandblast frame. Structurally it's all good but there are a couple areas with some extensive pitting and another few areas where the edge is thinned out. Wondering if I should try to build up then grind down the pitts/thin spots or use some sort of filler? Any suggestions would be welcome. Thanks. I plan on using POR15 for the finish.
AFAIK POR-15 will NOT adhere correctly to plastic filler/bondo.
If the areas aren't structural you might be able to lead solder them although i'm not sure if the POR will stick to that either.....
You could try a practice run on an old piece of scrap metal first.
More pix on Flickr.
Bondo Artiste
Bondo Artiste
After repairs and filler application after they are primed por 15 should adhere just fine. Call the Por 15 service line and ask them about primers that work well with Por 15.
~ Phillip
Thanks for the input. I looked at the POR15 site and they have a thickened POR15 in tubes that works as a filler. Figure I'll use that for the smaller pits. Guess I'll see what's left after sandblasting and decide how to proceed with deeper pits and thin areas.
