| | | Forums66 Topics128,010 Posts1,055,251 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 37 New Guy | | New Guy Joined: Mar 2010 Posts: 37 | I have a 1948 canadian chev cab and chassis,with an after market flatdeck. can someone enlighten me as to the difference in a 1 ton and a 3/4 ton frame??? Thank,s Doug | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy z48, to begin with the 3/4 ton has a wheelbase of 125 1/4", and a one ton has a wheelbase of 137". The frame on the one ton will probably be thicker/stronger as well, hope that helps. | | | | | Joined: Mar 2010 Posts: 37 New Guy | | New Guy Joined: Mar 2010 Posts: 37 | Thanx for the comeback 3B. I,ve noticed a difference in the kickup on some frames. this is were I was looking for some clarification. Thank,s Doug | | | | | Joined: Mar 2004 Posts: 874 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 874 | z48, The one ton chassis is flat on top in the back and the 3/4 ton chassis has a small kick up over the rear axle. At least that's the way it is on my two trucks. | | | | | Joined: Mar 2010 Posts: 37 New Guy | | New Guy Joined: Mar 2010 Posts: 37 | thanx Ghostrider,that is the info I was looking for. tell,s me mine is a 3/4ton Doug | | |
