6 members (37 GC, klhansen, Shade Baby, Reftys49, MaxStewart, Philipj), 95 guests, and 1 robot.
Topics128,143
Posts1,056,786
Members48,454
I would like to add a radio to my 6v truck and a 12 accessory plug so I can run a GPS, charge a phone etc. Don't want to convert the system to 12v as I like the 6v original setup.
I see that a number of vendors sell a 6 to 12v converter. I would like to get some opinions on what would be the best one to buy.
Kurt
Ex Hall Monitor
Ex Hall Monitor
If they're like many repop or specialty parts they're probably made by the same company. I'd go with the best warranty if I were buying one. There's a seller on ebay who told me he will make them to order and he charged less than the vendors.
Thanks. Good way to look at it.
Kurt
I would like to know what you finally end up doing. I miss having an electronic portable device portal in my 48. I had one in the 55 2nd but it was 12 volt.
I would like to have a 12 volt cigarette lighter in my truck.
Thank you
Dennis
H Online: Content
The simplest, and probably least expensive way to have 12 volts available is to install a small 12V battery like one for a garden tractor, and an onboard trickle charger. Just plug it in occasionally to keep the battery charged. Solid-state accessories like a normal radio/CD player, etc. (not some mega-watt booster) and power taps for cell phones, etc. use very little current. An occasional recharge overnight will keep the auxiliary battery topped out with no problems.
Do they make an inverter for 6v to 120v? I thought I had one years ago. Could plug a battery maintenance charger plugged into that. It would charge while you drove it.
H Online: Content
The conversion from 6VDC to 120VAC, then back to 12VDC would be terribly inefficient. Lots of losses every time the voltage got manipulated.
H Online: Content
Did you notice the output amperage? 800 Milliamps is 8/10 ampere. That MIGHT recharge a cell phone battery, but that's about all. It definitely wouldn't be able to power a radio, or run a cigarette lighter like someone suggested. I don't think that amount of current could even run a GPS system.
Here's a link to an article, thought it was interesting. Going to do something similar to my 54, in know i know mines a 12v, but the concept is interesting for USB devices
....David
David,
Down at the bottom of the article was a link to This.
At $4.95, how can you go wrong? 1.25 amps at 12v will surely run a phone or GPS device. Maybe not a radio though.
Kurt
H Online: Content
Looks good. I wonder if two of 'em could be run in parallel to double the amperage capacity?
Jerry,
I was thinking the same question, but maybe using 4 of 'em for a 5 amp solution.
Kurt
