5 members (74cheyennesuper, Ponchogl, NJC, baldeagle, Bill Hanlon), 63 guests, and 5 robots.
Topics128,014
Posts1,055,328
Members48,419
#848698 05/04/2012 12:49 AM
I ordered front brake lines for my 1966 GMC Suburban from Inline Tube. Had to buy a set of 4 (1 to master, 2 to wheels and one crossover.)Finally got around to replacing the cross over and it doesn't fit. None of the four look like they would fit any of the places they are supposed to go. I bought them a year ago so I'm not too concerned about eating them.
I know stainless would be next to impossible to home bend but has anyone bent their own in OEM type material?
I see some pliers like thing on Eastwood that they are bending brake lines with but the material seems like it would not bend that easily.
Any advice??
Jon S
Las Vegas NV
1966 GMC Suburban 305V6
Psalm 66 "Make a joyful noise"
http://i12.photobucket.com/albums/a205/gvdobler/0205011645b.jpg
Most flaps have hand bendable lines in varying lengths. I bend their regular lines by hand for sweeping bends. I use a small hand bender for tighter bends. It's shown in the tools I used to build the lines on my '56.
I also installed the dual master cylinder. There's some tips in there you can use if you've never done it.
Go for it. You'll feel good about it when it's done.
The only bad part about bending your own lines is the learning curve. When I finished with the first truck I should have just thrown away all the lines, because they did not look good and fit worse.
I've done more than one truck now and they look great and fit exactingly in place. It's just one of those things that takes a little time to realize how the tubing will bend and always double measure everything.
Remember, tubing is cheap.
Jeff
My 1953 Chevrolet
1947.1 Gallery
It is also advantageous to make up a pattern using welding rods. Doing this saves much cussing, just ask my neighbours.
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1949 GMC Panel Truck
1926 Model TT Truck
Forced to do my own for my one ton panel, nothing available from inline tube. I purchased a double flare kit with bender and dived into the project. Had to do one line the second time as well as had to learn the flaring procedure. Now it has been three years and my pedal is still perfect and have not lost any fluid. You can do it!
Karl
I redid all the brake lines on my 56 recently and I used the bendable lines sold at my local NAPA and Auto Zone. They are an olive drab color. I also used the very same tools Cletis shows in his picture. In fact, it looks like we have the same flaring kit. You might have a few do-overs, but like another poster said, there is a slight learning curve. For tight bends, use the hand bender and just go easy with it, a little bit at a time. If you try to make the entire bend in one spot, you'll kink the line, so move the tool around a little making little bends until you have the shape you want. Most other bends can be done with your hands--without the tool.
1956 Chevy 3200
Jon, I had the same thing happen to me... I called Inline Tube and turned out that my 54 had a different brake line configuration... Made a deal with them that I would return them the lines they sent and I paid shipping for my old lines to Inline... They made new lines from my old ones and shipped them to me ... The new lines fit perfect...
1954 Chevy 3104 3 Window Hydra-Matic in my family for over 60 Years
Once in a while you get shown the light in the strangest of places if you look at it right... "Scarlet Begonias" Grateful Dead 1974
Thanks for the input guys. The olive drab at Auto Zone did the trick.
Now if I can find the other #@##!@&*% leak, I'll be all set.
Jon S
Las Vegas NV
