| | | Forums66 Topics128,078 Posts1,055,936 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2011 Posts: 814 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 814 | I'll be installing a new engine in my truck pretty soon and while I'm at it, I'll either replace or reface the clutch components. I once had an experience with a pilot bushing where after pressing it into the crankshaft, its inside diameter decreased and I couldn't get the transmission in. I managed to address it with sandpaper on some round stock but it was not very accurate. I didn't have any problems with it but I've always wondered what the best way is of dealing with something like this.
1956 Chevy 3200
| | | | | Joined: Feb 2004 Posts: 29,780 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,780 | Sometimes it's not an undersize pilot bushing- - -it just gets distorted as it's driven into the end of the crankshaft. I like to hang the bushing on a piece of wire into a container of dry ice and alcohol so it shrinks enough to be a slip fit or just needs a light tap to get it into the crank. Once it warms up, the hole in the middle expands back to the right size and it's tight in the crankshaft. Be sure and use gloves- - - -the dry ice is something like 70 degrees below zero! Instant frostbite!
BTW, the same procedure works for valve guides- - - -freeze the guide and the driver together, then tap it into place in the cylinder head. It works even better if you warm the head up with a torch a little before driving the guide into place. Jerry
| | | | | Joined: Feb 2008 Posts: 320 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2008 Posts: 320 | Well it depends on how you install it to a degree. If you have hammered it in, the bonze is soft and peens easily. Pressing it in is best. The best way to resize it if its deformed is to ream it. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Last year I replaced mine. The truck was in the cold garage and the bushing came warm from the house. I had to really hammer it to get it in and I was quite worried. Fortunately it didn't distort but I learned not to do that again! | | | | | Joined: Sep 2011 Posts: 814 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 814 | Thanks for the responses. I will try the dry ice when it comes time to install the bushing. In the other instance I mentioned, I did drive the bushing in and it did distort somewhat. It was a thin-walled bushing compared to the ones I've seen on Stovebolts.
1956 Chevy 3200
| | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | This stuff available at industrial and electronics suppliers works quick and efficiently for sleeve or bushing installation.
1952 1300 Canadian 1/2 ton restomod You Tube | | | | | Joined: Sep 2011 Posts: 814 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 814 | That is really cool. I never knew there was such a thing.
1956 Chevy 3200
| | | | | Joined: Feb 2004 Posts: 29,780 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,780 | It's just Freon 134, available at any FLAPS. Probably cheaper that way, too. Just hold the can upside down when you open the charging tap to get liquid instead of gas. A CO2 fire extinguisher works better, if you have one handy. Jerry
| | | | | Joined: Jul 2012 Posts: 2 New Guy | | New Guy Joined: Jul 2012 Posts: 2 | Hydraulic Equipments Manufacturers Hydraulic Equipments and component to many of the machines and industries we take advantage of every day Read on to learn how u might be come to know about full information Hydraulic Equipment Manufacturer,Hydraulic Machine ... Hydraulic Equipment Manufacturer India Pneumatic Equipment Manufacturers,Hydraulic Equipment ... Hydraulic products manufacturers,Hydraulic equipment - TradeIndia Hydraulic Machines-India Hydraulic Machine Manufacturer ... Hydraulic Equipment Manufacturers | Fluid Separator | Pune for more details please contact http://www.perfectmachinefabric.com/ | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | This perfectmachine jerk has posted this same spam in at least 5 different posts.
This type of BS is enough to assure that no one would do business with a company like that.
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | My '38 has a pilot bearing instead of a bushing. Would the bearing fit this application? Why did Chevy get away from using a bearing in favor of a bushing?
| | | | | Joined: Apr 2010 Posts: 283 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 283 | Tiny, I think because of reliability issues. Small rolling element bearings are more fragile and harder to provide proper cleanliness and lubrication over the life of the clutch componants. cost should be lower for a plain bearing. A plain bearing will live with more abuse A plain bearing will carry more load for it's size than a rolling element bearing. Since the pilot bearing rotates entirely (no movement between the bearing componants)with the flywheel/input shaft most of the time, a reduction in friction would only benefit when the clutch is disengaged. A plain pilot bearing is nearly always reusable at clutch replacement time wheareas a rolling element bearing is nearly always unusable/destroyed. The bushing type bearing is normally made of porous(sintered-not made from solid)material so as to be self lubricating. Don't underestimate the seemingly low tech plain bearing.
Bob Taylor
| | | | | Joined: Sep 2006 Posts: 841 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 841 | thanks for posting the "cool can" 134. i didn't know they had that either. i always thought a roller bearing was better than a bushing? my hudson 308 had a roller bearing i replace with my rebuild a while back. the old one was in good shape but the new one came with the kit. i havn't had any trouble installing either but the rolling bearing took a little more care. the auto parts store told me the bushing is the same for the 30's up till 90's or something like that- i was pretty impressed with that. | | |
