4 members (UtahYork, Mike B, Otto Skorzeny, Danielbolt), 123 guests, and 2 robots.
Topics128,154
Posts1,056,857
Members48,456
Any and All,
I need to replace the shifter switch for my 454-30 dump truck. Switch is broken and crumbling.
I found a new switch on eBay, but no wiring diagram. Wires are in 3 different sections/pieces none of which are connected.
Anyone have the diagram to wire up a electric shift 2 speed. Circa 1952.
Thanx, wink
GMCPic
Dance like no one is watching,
Sing like no one is listening,
Love like you've never been hurt.
1948 GMC FC101 1/2t Pickup w/270 and SM420
1948 GMC FC253 1t Factory 80"x9' Flatbed Dually
1948 Chevy COE 2 Ton 8'x15' Flatbed
1950 GMC 354-24 2 Ton 8'X12' Flatbed w/Dump Hoist
1953 GMC 454-30 3 Ton 8'x14' Flatbed w/Dump Hoist
1953 GMC 454-30 3 Ton Cab and Chassis
1942 Clarkator 6 MILL-44 Heavy Aircraft Tug
1942 Ford (9N) Moto Tug with 1/2 yard Loader
1947 Oliver OC3 HG-42 Tract-Crawler Bull Dozier w/6' Blade
M Online: Content
GMCPix,
I assume you have the Red push/pull switch...
The switch is wired as follows;
Green = 12v from the Fuse Panel
Red = High Rear
Black = Low Rear
The Black wire will be Tee taped under the floor with a wire that goes up to the speedometer adaptor located at the dash. The adaptor keeps the speedometer accurate regardless of what speed the rear is in, it's a little electric reduction unit in-line with the speedometer cable.
Make sure you ground both the electric shift motor and the adaptor...
That's it!
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Got bigger problems now with shift unit.
When I hookup the switch and turn on key/power I get power to both terminals. Even when I disconnect one wire from switch terminal block.
Wires are totally rotten, crumble when touched.
So now I have to rewire the whole shift system.
Also, I am going to look into changing the shift motor too 12v.
Any ideas?
M Online: Content
GMCPic,
The switch and switch harness are still available new from Eaton. The switch is part number 32861 (about $10), I can't find the harness number. I think I got one from NAPA about a year ago.
The center terminal on the switch gets the hot wire from the fuse block. The top terminal is High speed and the bottom is Low.
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
Found some parts on ebay for old style Eaton 2 speed.
Now I have to find out if they will work.
Also I found another truck on Craig's list.
Going to look at it Sat.
