| | | Forums66 Topics128,164 Posts1,057,081 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2012 Posts: 124 Shop Shark | | Shop Shark Joined: Apr 2012 Posts: 124 | I am thinking of rebuilding the 3 speed transmission on my '59 1/2 ton Apache. Where can rebuild kits, seals, and gears be found. I did some searching on the web and didn't have a lot of luck. Any help would be much appreciated. Thanks a lot, Gene
Gene 1959 Apache
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Any good parts store should be able to get you the seals, and I know for sure that Napa can get the gasket kit (that's where I got mine). Here's a couple of places that you might also check with; http://www.drivetrain.com/parts_cat...kits/muncie_3_speed_ld_overhaul_kit.htmlhttp://www.mackstrans.com/MuncieID.htmlYou mention gears, are yours damaged? If so, you might consider hunting another transmission, if only to strip for parts. The SM318 is very common, and can be picked up fairly cheap at the swapmeets. Or better yet, look for the SM319 variant, with has a Borg-Warner overdrive. It's a bolt in swap if you can find either the Truck or the '55-'57 Passenger version. I see them fairly often in the $100-$150 range. Both transmission are very easy to service.
Bill Burmeister | | | | | Joined: Jul 2006 Posts: 187 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 187 | http://www.timken.com/EN-US/product..._Seal_Application_Catalog_1989_older.pdf Start around page 110 for all Chevy truck stuff. Some of your transmission parts will be on page 118. If you end up needing gears or housing parts, I think you'll be limited to buying good used parts. I rebuilt the transfer case on a 1963 K10 (I should've never sold)and ended up buying a donor Xfer case for gears etc. All other parts were either listed or I found a part number on them. Watts, OK is kinda in the sticks according to Mapquest but you can probably find a good bearing supplier in Tulsa. A good micrometer will help you locate all the parts you may need. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | If you are patient, place a "saved search" on eBay. I have been surprised to see how many different NOS 40s-50s 3-speed transmission parts show up regularly on eBay.
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I don't know if this is permited or ethical but if not the moderator can delete it. I have 2 real good trans. like that for sale. $50 each. I can send any parts of one you want or come to K.C. & pick one up. George They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Apr 2012 Posts: 124 Shop Shark | | Shop Shark Joined: Apr 2012 Posts: 124 | Thanks for all the info! Now I know what my options are. Thanks a lot, Gene
Gene 1959 Apache
| | | | | Joined: Oct 2011 Posts: 206 Shop Shark | | Shop Shark Joined: Oct 2011 Posts: 206 | DO you know if its a muncie 318? im assuming it is, but im not positive. if it is, I just saw muncie 318 kits for cheap on ebay | | |
