2 members (Guitplayer, 1 invisible),
174
Mod | | | Forums66 Topics128,196 Posts1,057,395 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2012 Posts: 102 Shop Shark | | Shop Shark Joined: Mar 2012 Posts: 102 | Hello, is this the orignal turn signal for my 46 truck? Turn Signal Turn Signal Box
1946 Chevy Truck Export Blue with Black Trim
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | there was no "original" turn signal for a '46 Chevy, but that is an era appropriate 3rd party [Montgomery Wards] unit
Bill | | | | | Joined: Mar 2012 Posts: 102 Shop Shark | | Shop Shark Joined: Mar 2012 Posts: 102 | Is there a better one made by chevy? If there is what does it look like?
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | I don't believe GM offered signals as an option until the mid-late AD years, and then it would have looked very similar .... nothing wrong with that one if you've got it or can grab it at a reasonable price
Bill | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | 1954 was the first year for a GM factory installed optional (RPO) turn signal set.
In earlier Advance-Design years (at least back to 1951), GM accessory turn-signal sets were available.
There is no accessory or optional turn-signal set in the 1946/47/49/50 USA Truck Data Book.
| | | | | Joined: Mar 2012 Posts: 102 Shop Shark | | Shop Shark Joined: Mar 2012 Posts: 102 | A friend told me that the correct turn signal kit would be made by Guide, did Guide make a turn signal kit for a 46 chevy truck?
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | if you're attempting to please show judges, any signal setup will be a non-factory addition .... Guide was a 3rd party supplier that produced signal assemblies, Signal-Stat was probably as common, and they were all basically the same, none would be "correct" as none were from GM directly .... the reason the one you picture indicates for 41 Chev is because the self canceling wheel fits the Chev steering wheel/column configuration, mostly a marketing thing, it could have fit other years and makes just as well, and it may have been a "re-branded" Guide or Signal-Stat unit
Bill | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Here is a photo of a turn-signal switch on Pat Sheridan's 41-46 Chevrolet truck that is displayed on his 1946 Chevy Truck Optional Equipment and Accessories
page. Send him an email message for information/documentation (Stovebolt name: Sheridan)? I do not see a turn-signal unit in the 1941 or 1946 Truck Data Book but it still might have been available - maybe Pat has an accessory parts list? Brad's '41 to '46 Chevies website is not working - he might also have documentation/information. | | | | | Joined: Mar 2001 Posts: 629 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 629 | Everybody is correct in that turn signals were not available for the 41-46 trucks. I did put signals on mine but it was for safety purposes. Typically Turn signals and seatbelts added will not detract from judging. I chose the signals that i did because it seemed to look the best in that era truck.
Tim Sheridan 1947 First Series Chevy 1/2-Ton"Liberty Series" - "Art Deco" - Whatever you'd like to call it. In the Gallery | | | | | Joined: Mar 2012 Posts: 102 Shop Shark | | Shop Shark Joined: Mar 2012 Posts: 102 | Everybody is correct in that turn signals were not available for the 41-46 trucks. I did put signals on mine but it was for safety purposes. Typically Turn signals and seatbelts added will not detract from judging. I chose the signals that i did because it seemed to look the best in that era truck. What model number turn signal is that installed on your truck? Is it made by Guide?
