3 members (cmayna, TUTS 59, 1 invisible), 146 guests, and 3 robots.
Topics128,070
Posts1,055,896
Members48,428
#847667 04/29/2012 11:12 PM
I am driving a 1959 1/2 ton Apache with a 235 and the original ignition. The truck runs good the way it is and I was wandering if an electronic ignition would give me any more power and improve my fuel economy. The catalogs all say that it will but they are trying to sell distributors. I thought some first hand advice would be helpful.
Thanks a lot,
Gene
Gene
1959 Apache
GeneWiseman #847690 04/30/2012 12:47 AM
You may save a gallon or so of gas over a few years time, but probably no more.
I like the HEI for ease of use and stronger starting. I have an HEI in my '47.1 COE and also a stock points system in my 6 volt '53 1/2 ton. Both are good systems, but the points systems do need to be adjusted on occasion. I really like the HEI setup in my COE as it really requires no care once installed.
I think for an everyday driver I would upgrade to the HEI, but you really don't need to. Six of one, half a dozen of the other.
Jeff
My 1953 Chevrolet
1947.1 Gallery
rustednuts #847730 04/30/2012 2:59 AM
What Jeff said. Think of it this way. The points need attention about every 1000 miles. If you drive about 1000 a year you might as well keep the points. If you put 1000 on it regularly you spend less time under the hood with HEI. I went with Pertronix on my Burb.
Cletis #848119 05/01/2012 3:01 PM
The idea that HEI systems are service-free is a myth. I've seen numerous HEI's with the centrifugal advance system totally worn out or locked up due to rust. A good high film strength lubricant needs to be used on advance parts and checked periodically, at least once a year on most systems. Just pull the distributor cap and rotor and check the weights and springs for wear, and dab a little high-temp grease on the pivot points. Ditto on the vacuum advance- - - -if it moves, it's good, but it takes a MightyVac pump or at least some mouth-powered suction on a piece of tubing to check for diaphragm leaks.
A friend of mine installed the HEI on his 50 Ford V8 he then had problems with poor starting, then he changed it back to the original pionts ,starts good now,
I have points in everything from my 1951 WD Allis Chalmers to my 1931 Harley Davidson all work good.
BILL #848390 05/02/2012 1:26 PM
Thanks for the info. I appreciate it.
Gene
Gene
1959 Apache
