2 members (Tinker5, klhansen), 178 guests, and 3 robots.
Topics128,195
Posts1,057,369
Members48,469
http://www.hotrodsbyhg.com/complete_cars/47_chevy_2ton/eng1.htm
does that enginelook like a 60s six or is it just me ? my 53 six has a few nuts directlyontopin centerof valvecover and looks morelike what a 50s 235 should look like, old style oil stick and road draft tube and all. light blue painted unlike the supposed 235in this pic
what do you think ?
otherwiset he truckis same as mine cept color and my interior is a little more straight than that
thanks
Randy the easter wabbit !
-here to help fellow enthusiasts as best as possible grin
parting some vehicles, 54 ford truck 57, chevy 210, 69 fairlane coupe HT and others,
I think it is a newer 235.
It has a 1954 valve cover on it. You can tell by the vent slots where the black blow-by has marked the cover. 235/261's used that basic cover from 54-62 with only miner changes.
My Blog
47 was the 216, not 235 - hard to tell from that angle what it is, but that doesn't look like a 47 valve cover to me
I remember someone was asking about changing the road draft tube to a pcv type system and I found this pic of a `54 Chevy 2-ton
[img]http://www.hotrodsbyhg.com/project_cars/54_chevy_2ton/eng1.jpg[/img]
there was the option on the big trucks of getting a 235 as early as the 42-46 models (got my chevy restoration guide and it has the toque curves and everything) since this is a 2-ton, being a 47 does not preclude it from having a 235...
that siad, I have no idea if that is or is not what those motors look like from that time.
-Mike R.
Anonymous
Unregistered
Anonymous
Unregistered
That early 235 was a splasher like the 216, not a full pressure system like the later 235. I think it had the tall side cover like the 216 also. Visually I think it looked just like a 216.
24601
24601
There does seem to be some confusion on the subject of the pre-54 splasher 235's in the big trucks. It sure would be cool if someone who had one, and it was correct, could send me a bunch of photos so I could make a page for it on the site.
I have a big truck ('49 4400) and someday it would be cool to find a splasher 235 to make it 100 percent.
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
John, I am installing a splasher-235 in my 1953 1/2-ton. I took this engine out of a 1951 3/4-ton thinking it was a 216. When the mechanic tore the engine apart and took measurements it spec'd out to a 235. Apparently a PO replaced the 216 with this 235. Externally this engine looks just like a 216. The 216 was the Thriftmaster and the 235 was the Loadmaster. The 216 was for the 1/2, 3/4 and 1-tons. The 235 was for the 1-1/2-ton, 2-ton and the Forward Control models.
I replaced the Babbitt bearings with insert bearings.
Jason
Junior Member
Junior Member
Actually, the 216 was the standard engine for the ton and 1/2 trucks as well. I had a completely original one family owned 4100 that had the venerable 216 in it. I researched the old Chevy literature, and it said that the 235 dipper was optional for the 4000 series and standard equipment for the 6000s. Hope this helps.
my 235 in the 53 has a valve cover larger than and nothing like the one in the above pic, hmm...
mines got like some raised lines grid pattern at the ends and one nut on direct towards both ends of the top of the valve cover. has vents for breathing and also road draft tube pass side.
for some reason it looks taller than a 235 should, also runs "meaner" especially at a hot fast idle, the way the fan and exhaust sound just make it seem that way anyways
