| | | Forums66 Topics128,147 Posts1,056,805 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#84795 10/26/2007 5:19 PM | Joined: Oct 2007 Posts: 388 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 388 | Hi,
I have 235 motor with bellhousing on it, I am trying to remove the bell housing from engine block to swap to 216 bell housing. I removed 2 bolts on the top of the bell housing to engine block and 2 behind the fly wheel on a difficult place to reach, however the bell housing wouldnot even move. I am kind of lost where else it can be holding to the block. Any suggesstions, thanks in advance | | |
#84796 10/26/2007 5:25 PM | Joined: Nov 2001 Posts: 1,519 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,519 | Theres 2 more behind the flywheel. You have to remove it to get to them. Marty | | |
#84797 10/26/2007 5:31 PM | Joined: Oct 2007 Posts: 388 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 388 | Thanks delux54panel, how to reach those bolts, cant even see where there located, any suggesstions
Thanks in advance | | |
#84798 10/26/2007 5:50 PM | Joined: May 2005 Posts: 12 Wrench Fetcher | | Wrench Fetcher Joined: May 2005 Posts: 12 | You will need to remove the flywheel to access the bolts that remain hidden. | | |
#84799 10/26/2007 5:54 PM | Joined: Oct 2007 Posts: 388 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 388 | Thanks Standonit, I am newbie to this, I thought flywheel is on the crankshaft and then clutch assembly will be mounted right, having bellhousing in place how do I remove flywheel, sort of baffeled
Sorry If I was not stating it right | | |
#84800 10/26/2007 8:47 PM | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy smokey_truck, you have to remove the clutch, if it's there, then you can remove the flywheel bolts and flywheel, now you have access to all the bellhousing retaining bolts, hope that helps. | | |
#84801 10/26/2007 10:13 PM | Joined: Oct 2007 Posts: 388 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 388 | Hey 3B
Thanks for answering , I will prey on it and update this message | | |
#84802 10/27/2007 12:45 AM | Joined: Nov 2001 Posts: 1,519 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,519 | Hi Smokey,,,As 3B said,,,remove the clutch assembly first. Then youll see the flywheel bolts. Theyll probably have "keepers" on them. Just bend the little nubs away from the bolts. Remove the flywheel and youll see the culprits that are still holding your bellhousing on. Make sure when replacing the flywheel,those bolts should be torqued. Dont know the exact ft.lbs. right off the top of my head,but i'll look in my shop manual for ya. Or if you have a shop manual,,its under,,"tightening specs". Make sure to use a clutch aligning tool when putting the clutch assembly back on. And,those bolts have to be torqued also. Marty | | |
#84803 10/27/2007 2:17 AM | Joined: Jun 2007 Posts: 95 'Bolter | | 'Bolter Joined: Jun 2007 Posts: 95 | This drove me nuts when I rebuilt my 235 this past summer ! Certainally, the operation is easier if your engine is out of the truck and on the stand. I agree with the others. It is impossible to acess the other two bolts unless you remove the clutch/flywheel on this engine.
J.D. Jordan
#84804 10/27/2007 2:24 AM | Joined: Oct 2007 Posts: 388 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 388 | Thanks guys, I will check that out and update you guys, man what a PITA this two bolts are, they are driving me crazy and a hot rod mechanic wants 2 big ones to remove that one
will keep you all posted | | |
