3 members (TUTS 59, Hugh63c10, Phak1), 212 guests, and 3 robots.
Topics128,089
Posts1,055,988
Members48,430
#84782 10/26/2007 3:43 AM
Apprentice
Apprentice
Wish this was an invite to a halloween party, but sadly it's referring to a strange low tone howl which develops between 40 - 55 mph. However when I let in the clutch and gas, there isn't any howl but a very slight vibration (from the front end) is just barely noticeable. It doesn't effect the steering in any way
I should mention that Pearl is a 51 chevrolet 1/2 T which has undergone extensive work on the undercarriage, including brakes / ball joints / drag link / all bushings etc.
What I am thinking is that it might be front wheel bearings, which weren't replaced, but were repacked. I've had the truck running for (the first time in 18 years) about a month since restoration. I haven't looked into the tranny yet or the rear end for fluid levels, but they might be next.
#84783 10/26/2007 4:07 AM
Junior Member
Junior Member
I would for sure drain and refill the tranny and rearend. I also read somewhere(LMC truck?) where you can update those old wheel bearing AND race to modern ones.Hope this quiets Pearl down. Give her a loving pat on the hood for me!! claychevy1
#84784 10/26/2007 5:31 AM
Apprentice
Apprentice
I'll get under this weekend and let you know,
#84785 10/27/2007 2:56 AM
A wheel bearing will make more noisy when turning so you can narrow down the search if it gets louder when turning left or right. A really bad bearing in the front will sound like a big lug mud tire with uneven tread, or like a smooth road with lots gravel tossed over it. Joe
