7 members (JW51, Hotrod Lincoln, Wally / Montana, texas46, TooMany2count, Jaison, 1 invisible),
120
Mod | | | Forums66 Topics128,082 Posts1,055,961 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2009 Posts: 56 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2009 Posts: 56 | I have a friend who is replacing the seals in my 4 bolt main and he is asking me the torque and tighting pattern to put back in. It is a 2 piece plastic/rubber type of seal, engine age uncertain but it is a 6 cyl, 235. Can anyone point me to or tell me the torque and pattern please. Thank you! | | | | | Joined: Feb 2004 Posts: 29,781 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,781 | According to my Motor truck manual:
Inner bolts 70 ft./lb. Outer bolts 65 ft./lb.
On the 200-some 4 bolt round track engines I've built, we always tightened the inner bolts first, then the outers. I use a good anti-sieze compound like Never-Seez, and reduce the factory torque spec by 5%, which would be 67 and 62. Torque specs are written for bolts lubed with 30 weight motor oil.
OOPS! Disregard the above info! That's for small block V-8 4 bolt engines! Back soon!
Motor lists 54-63 6 cylinder main bearing torque at 100-110 ft/lb with no difference for inner or outer bolts on the rear main cap. I'd suggest the same procedure, inner first, then outer. If you use anti-sieze, try 95-105 as a good spec. Jerry
| | | | | Joined: Aug 2009 Posts: 56 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2009 Posts: 56 | Thank you HotRod Lincoln for taking the time!!!!!! | | |
