| | | Forums66 Topics128,060 Posts1,055,840 Members48,427 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#84782 10/26/2007 3:43 AM | Joined: Mar 2006 Posts: 26 Apprentice | | Apprentice Joined: Mar 2006 Posts: 26 | Wish this was an invite to a halloween party, but sadly it's referring to a strange low tone howl which develops between 40 - 55 mph. However when I let in the clutch and gas, there isn't any howl but a very slight vibration (from the front end) is just barely noticeable. It doesn't effect the steering in any way I should mention that Pearl is a 51 chevrolet 1/2 T which has undergone extensive work on the undercarriage, including brakes / ball joints / drag link / all bushings etc. What I am thinking is that it might be front wheel bearings, which weren't replaced, but were repacked. I've had the truck running for (the first time in 18 years) about a month since restoration. I haven't looked into the tranny yet or the rear end for fluid levels, but they might be next. | | |
#84783 10/26/2007 4:07 AM | Joined: Sep 2007 Posts: 6 Junior Member | | Junior Member Joined: Sep 2007 Posts: 6 | I would for sure drain and refill the tranny and rearend. I also read somewhere(LMC truck?) where you can update those old wheel bearing AND race to modern ones.Hope this quiets Pearl down. Give her a loving pat on the hood for me!! claychevy1 | | |
#84784 10/26/2007 5:31 AM | Joined: Mar 2006 Posts: 26 Apprentice | | Apprentice Joined: Mar 2006 Posts: 26 | I'll get under this weekend and let you know, | | |
#84785 10/27/2007 2:56 AM | Joined: Feb 2000 Posts: 5,205 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,205 | A wheel bearing will make more noisy when turning so you can narrow down the search if it gets louder when turning left or right. A really bad bearing in the front will sound like a big lug mud tire with uneven tread, or like a smooth road with lots gravel tossed over it. Joe | | |
