3 members (RLB, Oswald, GRNHydra),
86
Mod | | | Forums66 Topics128,030 Posts1,055,430 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2012 Posts: 37 New Guy | | New Guy Joined: Apr 2012 Posts: 37 | I have a 55 second with this motor in it. I am a rookie, and need a little assistance. Can you fella's help me with what is correct, what is aftermarket, and what is missing? I know the crankcase breather is missing, and the air cleaner. What else might be missing? I have figured out the vacuum pump on the right side, and the fuel pump. The canister that I see on some earlier models on the drivers side, beside the carb, left side isnt there? Any help, or identification of parts is very helpful. I have figured out that the firing order is correct, and that there is a solenoid on the starter, so no foot stomp.ANy other info will be much appreciated. right side | | | | | Joined: Jun 2006 Posts: 693 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 693 | the canister on the left side is an optional oil filter, so it isn't surprising that that isn;t necessarily there. your heater hose ports are plugged, so your heater is not hooked up and may be missing.
also looks like someone put an alternator in there for battery charging, rather than a generator. | | | | | Joined: Apr 2012 Posts: 37 New Guy | | New Guy Joined: Apr 2012 Posts: 37 | It is looking less and less original all the time. So the story goes I guess. It will be interesting to post the rest of the pics later in the week and get the input on the rest of it. Thanks.
"Upon the plains of hesitation bleach the bones of countless millions, who when on the dawn of victory paused to rest, and there resting died." - John Dreschmer
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | That is a GMC so the oil filter was standard. It went on the right side. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Does the truck have a Hydra-Matic transmission? | | | | | Joined: Jun 2006 Posts: 693 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 693 | That is a GMC so the oil filter was standard. It went on the right side. now that you mention it - i should have looked more closely at the valve cover. i also noticed the brace rods running through the engine bay - my 56 chevy doesn't have those. also a GMC only feature? | | | | | Joined: Apr 2012 Posts: 37 New Guy | | New Guy Joined: Apr 2012 Posts: 37 | It does have the hydramatic. How could you tell from the motor pics? You have me stumped on that one.
| | | | | Joined: Sep 2011 Posts: 116 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 116 | Check the #'s on the ledge aft of the dizz., the first 3 #s will be engine size if it's a gmc. 1955 Second Series GMC"Done - A 50 Year Journey"Follow in the DITY-- No one said it was going to be easy
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy lostin55, Cletis probably surmised it may have a Hydramatic transmission because we can see a solenoid type starter on the engine. All Hydramatic equipped trucks use a solenoid type starter, rather than a "stomp" starter. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | .... I also noticed the brace rods running through the engine bay - my 56 chevy doesn't have those. also a GMC only feature? no Tom, a panel and burb only feature, to help prevent body wracking in cross winds the pics that lostin55 posted in the Welcome forum show the Hydramatic shifter in the interior shot Bill | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Hy lostin55, Cletis probably surmised it may have a Hydramatic transmission because we can see a solenoid type starter on the engine. All Hydramatic equipped trucks use a solenoid type starter, rather than a "stomp" starter. That got my suspicions up. Then I looked at the throttle linkage and that pretty much confirmed it. | | |
