5 members (Otto Skorzeny, RLB, TUTS 59, NJC, 1 invisible), 88 guests, and 3 robots.
Topics128,030
Posts1,055,430
Members48,422
#847631 04/29/2012 8:50 PM
I have a 55 second with this motor in it. I am a rookie, and need a little assistance. Can you fella's help me with what is correct, what is aftermarket, and what is missing? I know the crankcase breather is missing, and the air cleaner. What else might be missing? I have figured out the vacuum pump on the right side, and the fuel pump. The canister that I see on some earlier models on the drivers side, beside the carb, left side isnt there? Any help, or identification of parts is very helpful. I have figured out that the firing order is correct, and that there is a solenoid on the starter, so no foot stomp.ANy other info will be much appreciated.
right side
the canister on the left side is an optional oil filter, so it isn't surprising that that isn;t necessarily there. your heater hose ports are plugged, so your heater is not hooked up and may be missing.
also looks like someone put an alternator in there for battery charging, rather than a generator.
It is looking less and less original all the time. So the story goes I guess. It will be interesting to post the rest of the pics later in the week and get the input on the rest of it. Thanks.
"Upon the plains of hesitation bleach the bones of countless millions, who when on the dawn of victory paused to rest, and there resting died." - John Dreschmer
That is a GMC so the oil filter was standard. It went on the right side.
Does the truck have a Hydra-Matic transmission?
now that you mention it - i should have looked more closely at the valve cover.
i also noticed the brace rods running through the engine bay - my 56 chevy doesn't have those. also a GMC only feature?
It does have the hydramatic. How could you tell from the motor pics? You have me stumped on that one.
Check the #'s on the ledge aft of the dizz., the first 3 #s will be engine size if it's a gmc.
1955 Second Series GMC
"Done - A 50 Year Journey"
Follow in the DITY
-- No one said it was going to be easy
3B Offline
Hy lostin55, Cletis probably surmised it may have a Hydramatic transmission because we can see a solenoid type starter on the engine. All Hydramatic equipped trucks use a solenoid type starter, rather than a "stomp" starter.
Originally Posted by tomctomc
.... I also noticed the brace rods running through the engine bay - my 56 chevy doesn't have those. also a GMC only feature?
no Tom, a panel and burb only feature, to help prevent body wracking in cross winds
the pics that lostin55 posted in the Welcome forum show the Hydramatic shifter in the interior shot
That got my suspicions up. Then I looked at the throttle linkage and that pretty much confirmed it.
