| | | Forums66 Topics128,012 Posts1,055,311 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#84753 10/25/2007 4:21 PM | Joined: Oct 2006 Posts: 23 New Guy | | New Guy Joined: Oct 2006 Posts: 23 | Hi all,
I'm in the process of putting in a new engine in my '65 and while doing so, switched out the floor shift for an automatic column. I'm having a bugger of a time figuring out how to hook up the automatic column shifter to the TH-350 transmission. Any help is appreciated. | | |
#84754 10/25/2007 6:10 PM | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | I used all the linkage from a 1980 C10 | | |
#84755 10/25/2007 7:08 PM | Joined: Oct 2006 Posts: 23 New Guy | | New Guy Joined: Oct 2006 Posts: 23 | Did you have to do any cutting, welding, or other modifications, and did you also use the power steering unit from the S-10? I'm also thinking about adding power steering. | | |
#84756 10/25/2007 7:16 PM | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | That's a C-10, a half-ton truck, yes I robbed the steering box also. It's been a while, but I just took the linkage, spring, trans piece, bushing & frame bracket & all & it worked fine, had to drill 2 holes in the upper flange of the frame using a right angle drill for the little bracket to mount. | | |
#84757 10/25/2007 7:46 PM | Joined: Oct 2006 Posts: 23 New Guy | | New Guy Joined: Oct 2006 Posts: 23 | thanks '64. I'm gonna check out our local salvage yard and see what I can find. I checked out your photobucket too. Nice! | | |
#84758 10/25/2007 8:45 PM | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | Thanks, the two kids have put the brakes on my projects lately,,maybe someday they will get done. | | |
#84759 10/25/2007 10:01 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | There is a universale link kit avaiable that is adjustable. I think Summit has it & yogis also. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#84760 10/25/2007 10:26 PM | Joined: Oct 2006 Posts: 23 New Guy | | New Guy Joined: Oct 2006 Posts: 23 | '64, I know, I have two of my own (one and three years old). My truck will always be a "work in progress".
'wrench, I bought one from Lockar but it only seems to have about half of what I needed. I thnk it was the half from the tranny, but it didn't come with instructions so I'm kind guessing. I spoke to a guy at our salvage yard today and he's checking his yard for me.
Thanks again | | |
#84761 10/26/2007 3:10 PM | Joined: Apr 2005 Posts: 15 Junior Member | | Junior Member Joined: Apr 2005 Posts: 15 | If you get the lokar cable, you also have to get the aluminum piece that clamps on to the bottom of the steering column. I think the part no. is ACA-1804. That will hold the cable. The Lokar kit is kinda pricey. I am using that kit on one of my trucks, but I'm with '64, I'd try to use '80's linkage | | | | | Joined: Oct 2006 Posts: 23 New Guy | | New Guy Joined: Oct 2006 Posts: 23 | thanks guys,
I found a donor unit out of a '74 Chevy with a 3spd auto. I haven't installed it yet but it looks like it will work alright. | | |
