5 members (Wally / Montana, tclederman, 68ironhead, Goach2, Robert Crandall), 108 guests, and 3 robots.
Topics128,197
Posts1,057,263
Members48,466
what is my best option, lowest cost this 1/2 ton 235 is at best average.first swap 4.11 to 3.50 ring and pinion, bring the tube and rearend to shop.i looked at torque tube overhall manule it looks not to bad and i have acsess to the tools but getting the right gear mesh is not ez corect.second option get a junk yard 3.50 rearend and trans,get driveshaft cut to fit.third option is there a 3.50 carier that will fit my axle housing get a trans and driveshaft and welled the pivit bracket.i will take my time.thaks
Capital letters, proper punctuation, spelling, and complete sentences will probably get you an answer better than the confusing mess you posted. No, there's not a suitable 3.50 carrier assembly that will fit your torque tube setup unless you buy Patrick's 3.55:1 ring & pinion setup and retro-fit your gears.
ditto, learn to write 1st before you come here......
Sounds pretty harsh but you are on a technical oriented sited asking technical minded guys to take time out of their day to answer your questions. And you don't have time for proper punctuation?
