11 members (Tronman, Steelonsteel, Peggy M, Rusty Heaps, J Lucas, Wally / Montana, Scott, klhansen, Jon G, 2 invisible), 67 guests, and 1 robot.
Topics128,206
Posts1,057,433
Members48,471
1 Offline
Hi guys just wondering if anybody has patterns or knows of a supplyer for these wood pieces mine are rotten and cowl is out of alighnment causing door to jam.thx
Hi "New Guy" welcome to the Bolt-- didn't know there was any wood as late as 42.
Try this source--
KC Wood Manufacturing
470Rock Church Road, SW
Willis, Va. 24380
Ph. 540-789-8300
www.chevywood.com
Good luck,
Glenn
1 Offline
thx ill try them its the wood holding the front cowel to the floor / door pan kind of under the floor on each side.ill try to post a pick I might have to pull a good one from my truck for a pattern just thought id try here first somebody must have done it before...Here are some picks of what im talkin about.
[IMG]http://img.photobucket.com/albums/v249/jimbo42/panel/IMG_0632.jpg[/IMG]
[IMG]http://img.photobucket.com/albums/v249/jimbo42/panel/IMG_0633.jpg[/IMG]
[IMG]http://img.photobucket.com/albums/v249/jimbo42/panel/IMG_0634.jpg[/IMG]
[IMG]http://img.photobucket.com/albums/v249/jimbo42/panel/IMG_0635.jpg[/IMG]
[IMG]http://img.photobucket.com/albums/v249/jimbo42/panel/IMG_0636.jpg[/IMG]
[IMG]http://img.photobucket.com/albums/v249/jimbo42/panel/IMG_0637.jpg[/IMG]
1 Offline
Pleeeezzzz...there must be somebody here that has replaced these....searched all supplyers and nobody makes them......Sooomebody must have replaced them at one time...getting desperate dont whant to tear apart my good cab just for a patern.Anybody.......
It's called a toe board or floor toe board. The originals were metal. It's not unusual to see wood replacements done by owners as a "field repair". Mine has a floorboard replaced with plywood and it works just fine. It's possible to find a NOS metal toe board. I think Obsolete Chevy still has them. It's hard for me to tell from some of your photos but you may need more than just the toe board.
Harold Wilson
41 Chevy 3/4 Ton
1 Offline
Ahh dont think so Harold as the wood was in my burb and three trucks I have had. I think it is a factory wood.Yes there is a tin piece that goes over top that has the hi/low beam swithch.But I am pretty confident that the 42/46 chevys all need this wood toeboard If there is a metal replacement I would like to see picks of it. checked obsolete chevy and this is all they have.thx den
http://www.parts123.com/PartFrame.a...com&TITLE=Obsolete_Chevrolet_Part_Co
Exactly what do you have..pickup, panel or?? Maybe that is a Canadian thing?? Trucks built there often have slight differences from U.S. versions. My '40 has no wood that I have found, other than blocks under the bed.
1940 Chevy 1/2 ton pickup "KC"
A day without sunshine is like, well, ..... dark!
1 Offline
Hi I have a 46 panel and 2 46 pickups and they all have the wood.like in the picks posted the one pick is pretty clear and the other is a pick from the bottom looking up. They seem to just be some kind of wood spacers if yours is stricktly metal I would like to see some picks mayby I can adapt mine.
I think you may be talking about the cab mounting blocks that fit between the cab & the frame. I think many of the parts suppliers; Jim Carter, Chevs of the 40s, etc have them. They used these on the '40's trucks.
1939 GMC AC-102 Long Bed 1/2-Ton
In the Legacy Stovebolt Gallery
More details in his DITY Bay
1940 Chevy WB Series 1.5-Ton
1 Offline
Nope I know what mounting blocks are .... have a look at my picks its pretty self explanitory.I am beggining to think I have the only trucks, panel with the wood in floor in the world.
