| | | Forums66 Topics128,196 Posts1,057,388 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 34 New Guy | | New Guy Joined: Sep 2007 Posts: 34 | Hi guys just wondering if anybody has patterns or knows of a supplyer for these wood pieces mine are rotten and cowl is out of alighnment causing door to jam.thx | | | | | Joined: Mar 2006 Posts: 143 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2006 Posts: 143 | Hi "New Guy" welcome to the Bolt-- didn't know there was any wood as late as 42. Try this source-- KC Wood Manufacturing 470Rock Church Road, SW Willis, Va. 24380 Ph. 540-789-8300 www.chevywood.comGood luck, Glenn | | | | | Joined: Sep 2007 Posts: 34 New Guy | | New Guy Joined: Sep 2007 Posts: 34 |
| | | | | Joined: Sep 2007 Posts: 34 New Guy | | New Guy Joined: Sep 2007 Posts: 34 | Pleeeezzzz...there must be somebody here that has replaced these....searched all supplyers and nobody makes them......Sooomebody must have replaced them at one time...getting desperate dont whant to tear apart my good cab just for a patern.Anybody....... | | | | | Joined: Jan 2003 Posts: 354 'Bolter | | 'Bolter Joined: Jan 2003 Posts: 354 | It's called a toe board or floor toe board. The originals were metal. It's not unusual to see wood replacements done by owners as a "field repair". Mine has a floorboard replaced with plywood and it works just fine. It's possible to find a NOS metal toe board. I think Obsolete Chevy still has them. It's hard for me to tell from some of your photos but you may need more than just the toe board.
Harold Wilson 41 Chevy 3/4 Ton
| | | | | Joined: Sep 2007 Posts: 34 New Guy | | New Guy Joined: Sep 2007 Posts: 34 | Ahh dont think so Harold as the wood was in my burb and three trucks I have had. I think it is a factory wood.Yes there is a tin piece that goes over top that has the hi/low beam swithch.But I am pretty confident that the 42/46 chevys all need this wood toeboard If there is a metal replacement I would like to see picks of it. checked obsolete chevy and this is all they have.thx den http://www.parts123.com/PartFrame.a...com&TITLE=Obsolete_Chevrolet_Part_Co
| | | | | Joined: Mar 2011 Posts: 457 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 457 | Exactly what do you have..pickup, panel or?? Maybe that is a Canadian thing?? Trucks built there often have slight differences from U.S. versions. My '40 has no wood that I have found, other than blocks under the bed.
1940 Chevy 1/2 ton pickup "KC" A day without sunshine is like, well, ..... dark! | | | | | Joined: Sep 2007 Posts: 34 New Guy | | New Guy Joined: Sep 2007 Posts: 34 | Hi I have a 46 panel and 2 46 pickups and they all have the wood.like in the picks posted the one pick is pretty clear and the other is a pick from the bottom looking up. They seem to just be some kind of wood spacers if yours is stricktly metal I would like to see some picks mayby I can adapt mine. | | | | | Joined: Aug 2006 Posts: 129 Shop Shark | | Shop Shark Joined: Aug 2006 Posts: 129 | I think you may be talking about the cab mounting blocks that fit between the cab & the frame. I think many of the parts suppliers; Jim Carter, Chevs of the 40s, etc have them. They used these on the '40's trucks. | | | | | Joined: Sep 2007 Posts: 34 New Guy | | New Guy Joined: Sep 2007 Posts: 34 | Nope I know what mounting blocks are .... have a look at my picks its pretty self explanitory.I am beggining to think I have the only trucks, panel with the wood in floor in the world. | | |
