7 members (Opelika Tom, Bigdogg, panel fan, 52Carl, carbking, 1955 1 Series, moparguy),
347
Mod | | | Forums66 Topics128,164 Posts1,057,083 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2011 Posts: 420 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 420 | i got a factory t-5 from a 89 s-10 and a 3:08 rear(?) from a 88 s-10 any idea how its gonna run ?? | | | | | Joined: Feb 2004 Posts: 29,871 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,871 |
| | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | For years the standard rear end for an OD was 4.11. You can fudge on this down to 3.73 if no load hauling or trailer pulling is in the picture. T5's had several OD ratios from about 18% to near 30% so you need to find out what you have. If you have a 30% then take 0.7 x 3.08 and you get 2.16 for a final drive ratio in OD. You didn't mention your engine so if it's a 502 big block with twin turbos then it can handle it.
Evan
| | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | If you have a 502 big block your going to bust that T-5. The T-5 is a good alternative, just make sure you get the right combination. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | It all depends on what engine you running & the o-drive ratio of the T-5. A lot of the late 80,s & early 90,s T-5 trans. used a .86 o-drive. It might work good if you don't have a real strong engine. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jun 2011 Posts: 420 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 420 | im running the original 216 for now, planning on a 235or bigger 6 later on
| | | | | Joined: Feb 2004 Posts: 29,871 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,871 | You'll have trouble making that one run above 3rd. gear. 4th. is direct drive, which would work with the 3.08 on level ground, but would accelerate very slowly, if at all and would have teouble on any sort of hill. 5th. gear would be a total wasted effort- - - -not enough torque from the 216 to maintain speed, even on level ground, most likely. Jerry
| | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | I second what everbody else has said. Not a good combination for sure. However, tire size might also come into play with your calculations.
2000 rpm is a good place to be at 60 mph for a 235 6 cylinder motor. 3.08 gears with 26 inch tires (205/70r15)and a .86 od put you pretty close to 2000 rpm at 60mph. Most of us run taller tires on our trucks.
I prefer lower gears for better acceleration and grunt. I currently have 3.70 gears with a .73 od in my truck, but will be changing the gears to a 4.33:1 ratio to get a little more grunt. The 3.7 gears worked well with 28 inch tires (275/60R15) but do not work well with my current 31X10.5R15 tires.
There are a lot of variables to consider when building these trucks including but not limited to the following Size of truck Size of tires Rear end Gear availibility Motor Transmission How it will be used... work truck? daily driver? Personal preference budget etc.
What might be "gold" to one may be "crap" to another.
John | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | 3.08 gears are too high for the 216 without the o-drive. Like Big daddy says it would probably work ok with a 235. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | I have this ratio but with a 261, the trans is great for lots of reasons but I've only had her in OD gear on a few occasions. Just went to a less tall tire on the back but at next opportunity I'm going to around a 3:50 rear end ratio.
| | | | | Joined: Jun 2011 Posts: 420 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 420 | how about if i install a 3.73 ring and pinion from speedway motors in it?? | | | | | Joined: Feb 2004 Posts: 29,871 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,871 | That would be a much better choice. Be aware that most of the racing type R&P sets will have a little bit of gear noise when run in a vehicle with a moderately quiet exhaust system. When my son's Dodge Ram broke a pinion gear shaft, we replaced the gearset with one from Richmond Gear. It ran and pulled well, but I was never quite able to adjust the whine out of the gears, even after doing a lot of measuring and tooth pattern checking. Jerry
| | | | | Joined: Jun 2008 Posts: 19 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 19 | A little personal experience. My 53 GMC was originally set up with a 228 and S10 T5. I checked the Hollander and found that all S10's with T5's were equipped with 3.42 rear gears (but 14"tires, remember)..Anyway I set up my Camaro rear end with 3.42s and all was well. Since then I've installed a hot rodded 270 with a Camaro World Class T5 which has the .72 or .73 Overdrive. Still works well, but I think the 3'73 rear gears might get the fuel mileage up over 20 instead of 19.6. Im turning about l850RPM at 70 MPH (verified by GPS) I feel the engine would like it better if it was turning about 2000 at 70 MPH. | | |
