0 members (),
79
0
Mod | | | Forums66 Topics128,035 Posts1,055,560 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2010 Posts: 255 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 255 | Got my back up light mounted (Guide B-31), and a push/pull switch mounted to dash. Should I put a fuse in the circuit - and where (in the "hot" wire to switch, or between switch and lamp)? If a fuse is needed, what size or rating. I have a 6 volt system. Thanks in advance. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the factory accessory backup lites take a 9a fuse, so I'd think that'd be advisable - should go in the supply wire before the switch
Bill | | | | | Joined: Mar 2011 Posts: 457 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 457 | Yep, I agree with Bill. And, love your truck!
1940 Chevy 1/2 ton pickup "KC" A day without sunshine is like, well, ..... dark! | | | | | Joined: Aug 2010 Posts: 255 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 255 | Thanks guys - wiring the light up without a fuse just seemed like "askin' fer trouble" - I will install an inline fuse as suggested. Thanks again. | | | | | Joined: Feb 2004 Posts: 29,760 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,760 | A fuse needs to be able to carry enough current to power whatever item is being operated, and have a low enough capacity to protect the wire in case of a short. The bigger the wire, the bigger the fuse can be. A 16 gauge wire should have a 10 amp or smaller fuse, while a #12 wire can go up to a 15 amp, 20-25 amp for a #10, etc. Jerry
