3 members (TUTS 59, JW51, Jon G), 114 guests, and 4 robots.
Topics128,095
Posts1,056,480
Members48,444
#846506 04/25/2012 3:43 PM
I have a set of the reproduction tail lights on my 49 gmc. Each tail light has two single filament bulbs inside. I am using bulbs that say 12v on the package, however, I can't seem to keep bulbs alive in one of the tail lights in particular. I check em, and they are indeed burned out when I change em. What the heck is up?
Are they burned out or broken filaments? Burned out would indicate an electrical problem, broken filament would indicate a vibration problem.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
hmmm. I will have to get the bifocals out to be sure.
Ex Hall Monitor
Ex Hall Monitor
Are the bulbs made in China? I bought a whole box of Chinese made headlight bulbs for my '38 (prefocus base) and none lasted more then a few seconds before burning out.
I have been getting them at the local auto parts places. I do think the packaging said sylvania....but also said made in china. None of them seem to last more than one or two rides.
I guess China doesn't seal the bulbs well enough, air gets in and poof. I work a parts store and the returns are crazy on China-made bulbs-many blow upon the first use. Chinese quality is lacking.
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
That is what I am starting to think here. I also got a headlight from the same flaps that was not glue together squarely. It would not fit in the headlight retainer ring. Being out in the boonies, I gently nipped off a fraction of glass off the outer rim to make it fit. If I had been in town it would have gone back to the store forthwith.
You may by sending a shock wave to the bulb when you close the hood. Slamming the hood sends good jolt to the bulbs in some cars.
1954 Chevy Half-Ton
More pix on Shutterfly
More pix on Photobucket
1958 Chevy 1/2-Ton Stepside
"Time's fun when you're having flies." ~~ OLD FROG
