4 members (FAST55, lumbersawyer, tclederman, 1 invisible), 73 guests, and 2 robots.
Topics128,023
Posts1,055,367
Members48,420
#846421 04/25/2012 3:22 AM
first ill say thanks for all the help thus far,i now have a sending/pickup tube and emergency brake cables.frame/motor is done now im heading to the cab,i guess because i have the cab already pulled off i should probably go and do the floor.lmc makes a wood floor kit but i was really wanting to do a tounge and groove type floor,but im not finding boards wide enough for the 10 inch spacing,if i do go with the lmc kit,would i order one for a fleetside short bed?did the panel truck come with the steel runners?thanks in advance
tjknaus #846425 04/25/2012 3:34 AM
early series panel bodies [pre-55] used planks, later ones [55+] have plywood floors, and yes they all had the skid strips - but the year is needed to say anything specific
Flxible #846439 04/25/2012 4:49 AM
8
8 Offline
From a Stovebolt search.
LINK
I do not think that you will get the 1949 Panel rear floor boards out in one piece.
In 1950, "the floor boards of panel and canopy express models were changed to plywood construction. In the new construction a single panel of wood and five skid strips replaced thirteen floor boards and twelve skid strips."
LINK
Originally Posted by TooMany2count
my question is this, my bus/panel/bus had slats of wood in it like the pickups & i had another 1 ton panel w/plywood like most of you folks know. so what years got slats & plywood, OR could of it been the assembly plant they were made at????joe
LINK
Dave,
The plywood provided more structural integrity and less dust leakage. In case you do not know this, boards/planks were used in Panels through 1949.
If you are not going to use the Panel metal strips, either save them or sell them in the Swap Meet.
Good luck,
Originally Posted by Mar-Ktech
TooMany2count:
Yes we do make parts for Panel/Burbs. You'll have to look online - just put in your year, make and model and the parts available list pops up on the left hand frame.
IF your year doesn't show a panel/burb as one of the dropdown options then you can fill out the custom forms and and we'll make you one! The custom forms are here:
http://www.mar-k.com/CustomForms
You can also find them in the paper catalog.
Thanks!
An elephant is a mouse built to government specifications.
80_Grit #846465 04/25/2012 10:17 AM
It looks like tjknaus has a 1956 panel. It would have originally had a plywood floor, as posted by Bill.
Regarding buying fleetside bed-wood for a panel rear floor - I doubt that would work, but wait to hear from someone who knows about post 55-2nd+ panel trucks.
Plywood floors in panel trucks started in 1950 (with 5 metal skid strips).
yep Tim, my 52 had the one piece plywood floor and skid strips and is original and a one piece plywood sheet would have to be special ordered as they are wider than average board today. I think somewhere around 54".
Do a search and find lots of reading!
54" width is correct, Alvin. The same width as in the Suburban.
I have heard people say they could find plywood that wide a boat-repair parts company.
Leo Offline
Moderator
Moderator
You're getting into a heap of work if you want to replace the plywood with plywood. I think Weeds did it a few years ago, although his is the A-D series.
Leo #846652 04/26/2012 2:04 AM
ok my bad,its actually a 2nd series 55 but titled as a 56.it does have a plywood floor in it now,actually looks like treated plywood thats 3/4 inch thick.im not doing a full restore gonna be custom,any ideas on a cool floor concept,im gonna go with some kind of toungue and groove flooring with a dark stain,any ideas
tjknaus #846660 04/26/2012 2:17 AM
If you go with solid wood, you're going to want the load strips between the planks. The wood is going to expand and contract, and the strips will hide the gaps.
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1949 GMC Panel Truck
1926 Model TT Truck
Leo #846662 04/26/2012 2:21 AM
guess I misremembered, was thinking the ply floor started later ....
I've done the floor on the TF series, parted out a '58 and saved the good [oil saturated] floor to replace the one in my old driver, and while it was out I used it for a pattern to make a new floor for another '57 .... a sheet big enough would have been a very expensive special order with months of waiting, so I got 2 sheets of over length marine ply [10'] and made the correct width with a biscuit joint down the middle .... it definitely is a major job
tongue and groove fir floor in my '58 driver - done with salvaged fir flooring, don't think I'd want it in a panel tho'
Flxible #846667 04/26/2012 2:28 AM
Bill, you shoulda come down, we coulda scarfed the ply together, no biscuits needed!
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1926 Model TT Truck
Flxible #846674 04/26/2012 2:46 AM
bill was there any problems with the planks that wernt bolted,they try to come up or anything
tjknaus #846681 04/26/2012 2:55 AM
did that ply years ago Chris, in my neighbors most excellent wood shop
tj - I bolted most all of the planks, and if you finish all 6 sides before assembly, then do an undercoat once it's together it might work OK sheltered in a panel - with the pickup exposed in my wet climate, there's been some cupping and shifting after about 15 years of daily hard use, it needs a good sanding and repaint .... when I get a round tuit grin
tjknaus #847227 04/28/2012 3:17 AM
I used three sheets of 3/4 tongue and grovve plywood. I used the old floor as a template and placed the sheets crosswise, breaking them at the wheelwells. Also used asphalt roofing compound underneath to waterproof the ply. I tried icedam sheeting but would not stick to a horizontal upsidedown position. I'm gonna cove the ply with melamine strips when i put the steel runners back in as a spoil type board situation. i did the research on a full sheet of ply and a 500 dollar prictag was not worth it. I did 3 sheets of t and g for about 120 and im very happy with it plus it was way easier to install in sections. peace.
1957 3805 Panel
It's not how you fall down, but how you get back up.
tjknaus #847720 04/30/2012 2:41 AM
https://www.stovebolt.com/ubbthread...Main=100320&Number=690514#Post690514
This worked well for me as long as the original floor is in decent shape.
Don J wave
1964 Chevy Panel
"The Good Karma Project"
More pix on Photobucket
1957 Chevy Panel
May be goin' to Hell in a bucket, but at least I'm enjoying the ride! ~ Jerry Garcia
mrduck #848006 05/01/2012 2:59 AM
well i just bought 50 sq feet of white pine tounge and grove flooring and im going to give it a try,if it works it should be awsome looking
Flxible #853149 05/22/2012 3:10 AM
got my floor done,dont know how to post pics though,but it looks awsome
tjknaus #853538 05/23/2012 7:41 PM
click on the bottom left of the page for how to post pictures.
In short...load them up to a site like Photobucket then post a link to that page. Once you do it one time you'll be set. There are guys here to that can walk you though it batter than me!!
We do want to see those pics.
tjknaus #853665 05/24/2012 3:49 AM
tjknaus #853717 05/24/2012 1:25 PM
Thanks. Nice job on the floor. As my daddy always said, there is more ways than one to skin a cat. Good job.
