3 members (jmoore, gswbbc, Lightholder's Dad), 67 guests, and 3 robots.
Topics128,031
Posts1,055,434
Members48,422
#84658 10/23/2007 7:06 PM
I have access to some 70-72' chevy power steering set ups and am considering installing them in a 63' C10. Any ideas, problems, info would be appreciated.
DJ
dj durant
More pix on Flickr
#84659 10/23/2007 9:43 PM
DJ,
It's a bolt on providing you obtain the gear box bracket kit which is available from various suppliers. Use the gear box, hoses, pump & brackets, pulleys, and rag joint from the 70-72. It is also necessary to cut & weld the shaft in the steering column.
Fred
#84660 10/23/2007 9:44 PM
Riding in the Passing Lane
It,s a pretty basic swap. There is a bracket kit available to mount the gearbox to the frame. Most specialty suppliers have it. It can be done with out it but is a better, cleaner, safer, job with the kit.
1972 Chevy c10 Cheyenne Super
