5 members (TooMany2count, tclederman, Gray_Ghost, 2 invisible), 85 guests, and 0 robots.
Topics128,132
Posts1,056,386
Members48,441
#846361 04/24/2012 10:41 PM
1 Offline
found this in a pile of parts I bought what is it says 46 radio but looks like an ancient speaker to me.
[IMG]http://img.photobucket.com/albums/v249/jimbo42/panel/IMG_0639.jpg[/IMG]
[IMG]http://img.photobucket.com/albums/v249/jimbo42/panel/IMG_0640.jpg[/IMG]
[IMG]http://img.photobucket.com/albums/v249/jimbo42/panel/IMG_0638.jpg[/IMG]
161616 #846368 04/24/2012 11:21 PM
Looks similar to a radio I saw in a 40 Chevrolet car. The controls were a separate little box with a dial and knobs. Open it up and see if there are typical tubes and such inside.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
I would expect there to be a couple of fittings where mechanical control cables attach. Open it up and you may find a name and model number.
1951 1 Ton Completed
It's a "MOTOROLA" radio made in the 40's aftermarket They had there own connections, mounted on the fire wall with a head controls, Motorola had a wide range of optional heads, some could fit the dash like original equipment, Some years ago I cleaned out a radio shop that sold Motorola I've still got set like this and heads NOS, not really worth much, I use them for parts!
BILL #846940 04/27/2012 1:27 AM
1 Offline
Thx Bill could you post a couple picks of your radio with the heads then mayby I could collect the parts from a swapmeet or at least know what im looking for.
161616 #847074 04/27/2012 2:58 PM
I'll see what I've got left , It's not uncommon to find NOS heads for Motorola at flea markets, most that I had I robbed the Knobs, some are close to OME in looks ,only they use set screws and not the half shaft with springs found on GM radios
BILL #848512 05/03/2012 2:04 AM
Take a look at this post & you will see what a 1946 Radio looks like.
https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=839932#Post839932
Harold
Harold
Moderated by  truckernix
