1 members (homer52), 66 guests, and 4 robots.
Topics128,072
Posts1,055,906
Members48,429
#846410 04/25/2012 3:01 AM
So, here's a question that is sure to make you laugh:
How much work is it to mate a car front end (1952 Chev) to the front end of a 1/2 ton pick up truck?
Does the truck frame just sit on the front clip (if thats the right term) where the car frame sat? Is it a "bolting" up sort of situation?
See, I told you this would make you laugh..... I'm laughing! I'm just looking to get educated here.
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1949 GMC Panel Truck
1926 Model TT Truck
Why is that a dumb question? I don't own a Chevy at the moment but am in the process of swapping front suspensions on my '53 F100. There are alot of "kits" out there but I'm not sure that any of them are a simple bolt on. The one I'm using is supposed to be but there's no way I'm driving it at highway speeds without that puppy being welded in. I think the key to the sway is to find a donor vehicle that has a similar frame width. The older MOPAR B-body K-members are a close match for 48-56 F100's. Here's a link to my photos: F100 and if you're brave enough to stray to the other side; here's a link to the steps I've been through so far (only worked one weekend on it so far). my Gibbon IFS swap
8
8 Offline
49/50/51/52/53/54 Chevy Car front suspension in AD Truck.
An elephant is a mouse built to government specifications.
Ohhhh, that's a good link! I never thought to search at the HAMB, duh! Hahahaha.
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1926 Model TT Truck
depends on your fab skills. done a gen3 camaro front clip to a '53 chevy 1/2 ton, actually wasn't that difficult. we welded it together. just watch your level and set for your desired ride height. my have to tack it in and reassemble to check before finalizing it.
daren
1952 GMC 1-Ton
1946 plymouth
1947 ford
custom builder
http://www.doublegcustoms.com
I know a few guys here locally who have this done to their A D trucks and suburbans and they perform great.
Its exactly what i will be doing to my 49' burb to get away from the straight axle and to keep it looking period correct.
