| | | Forums66 Topics128,113 Posts1,056,614 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 29 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 29 | Hello, I've searched an I am sure this has been covered but I can't find anything so my appoligies in advance for asking.
Other than the obvious, length, what are the differences between a 1/2 ton frame and a 3/4 ton frame? I need to undo a subframe on a project I bought. The truck was 3/4 ton and the previous owner shortened the frame and bed and made it a short wheelbase. It also had a subframe added which I have removed.
I have a 1/2 ton frame front section and would like to graft it on to my frame. The 1/2 ton frame seems thinner. I suppose what I am asking is are both frame sections from the cab forward the same?
Brent Wagner | | | | | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | | | | | | Joined: Dec 2006 Posts: 29 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 29 | The truck is a '49 but with all the changes the previous owner made who knows what year the frame is, although I suspect the frame and body are mates. | | | | | Joined: Dec 2006 Posts: 29 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 29 | I also noticed some time back that the rails on another 3/4 ton I own are the separated the same distance from front to rear. And the 1/2 ton frames are spread more in the rear than the front.
Nevertheless my graft will be about 10" in front of the lower cab. Aside from the spread are the rails basically the same on the 1/2 ton and 3/4 ton?
| | | | | Joined: Apr 2012 Posts: 35 New Guy | | New Guy Joined: Apr 2012 Posts: 35 |
An elephant is a mouse built to government specifications.
| | | | | Joined: Dec 2006 Posts: 29 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 29 | | | |
