0 members (), 106 guests, and 3 robots.
Topics128,089
Posts1,056,440
Members48,443
Hello, I've searched an I am sure this has been covered but I can't find anything so my appoligies in advance for asking.
Other than the obvious, length, what are the differences between a 1/2 ton frame and a 3/4 ton frame? I need to undo a subframe on a project I bought. The truck was 3/4 ton and the previous owner shortened the frame and bed and made it a short wheelbase. It also had a subframe added which I have removed.
I have a 1/2 ton frame front section and would like to graft it on to my frame. The 1/2 ton frame seems thinner. I suppose what I am asking is are both frame sections from the cab forward the same?
Brent Wagner
what year is your truck
1941 Chevy Master 3/4-Ton
More images in the Bolt Bucket
Born to fish, the truck is only a hobby.
The truck is a '49 but with all the changes the previous owner made who knows what year the frame is, although I suspect the frame and body are mates.
I also noticed some time back that the rails on another 3/4 ton I own are the separated the same distance from front to rear. And the 1/2 ton frames are spread more in the rear than the front.
Nevertheless my graft will be about 10" in front of the lower cab. Aside from the spread are the rails basically the same on the 1/2 ton and 3/4 ton?
8
8 Offline
An elephant is a mouse built to government specifications.
Thanks so much.
